Latest post Thu, May 8 2008 10:50 AM by cluas. 7 replies.
  • Wed, May 7 2008 10:32 AM
    • cluas
    • Joined on Tue, Oct 23 2007
    • Posts 9
    • Points 75
    omf export problem; file size is much bigger than it should be
     Hi I am hoping someone can help me.
    I have 2 sequences, which are very similar, length, size, track numbers etc.. when i consolidate and export the 1st one it is the normal size of approx 700mb (as have all 6 sequences i exported before this!)
    when i export the 2nd one it is over a gig in size which i know is wrong. i have redone it numerous times, trashed my settings, re-consolidated and every time it comes in over a gig. i am doing exactly the same thing for both sequences.
    I am using media composer v10.7.5 , 8 audio tracks, 26 mins duration sequences.
    any help would be greatly appreciated.
  • Wed, May 7 2008 10:41 AM In reply to
    • camoscato
    • Posts 4,120
    • Points 49,425
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    Re: omf export problem; file size is much bigger than it should be
    Is there anything that differentiates the problem sequence?  More effects, maybe?
    good luck,
    Carl
  • Wed, May 7 2008 12:19 PM In reply to
    • fiendish
    • Posts 195
    • Points 2,355
    Have you tried completely fresh user settings? Saw this recenty on 2.8 it was down to corrupt user settings
    MC 3.0 / QT 7.4.5 on xw9400 with Mojo SDI - 4gb / quadro 3500 and 3ware 9650SE Raid 5 (and flamethrowers!) [view my complete system specs]
  • Wed, May 7 2008 3:30 PM In reply to
    • cluas
    • Posts 9
    • Points 75
    I totally trashed my settings and made new ones, but havent tried using someone elses yet. there are no real differences between the sequences, very little effects too its a basic dialogue, atmos and some music sequence really.. baffling...
  • Wed, May 7 2008 4:10 PM In reply to
    • cluas
    • Posts 9
    • Points 75
     double checked its media composer v10.5
    ive since tried exporting just the audio tracks 1 and 2 , the file size was over 500mb (which is nearly the size of the entire other seq) i then re-imported it back into my system and it seemed to work fine. but its still a mystery why its nearly twice the size of the other sequence....
  • Wed, May 7 2008 6:18 PM In reply to
    • dor
    • Israel
    • Posts 160
    • Points 2,025
     Do you have group clips in your sequence?
    MC 3.0 + MOJO SDI. P.4 3Ghz + 2GB RAM [view my complete system specs]
  • Thu, May 8 2008 9:07 AM In reply to
    • cluas
    • Posts 9
    • Points 75
     No group clips, its a really basic sequence.
    the only thing i can think of is the source tapes are recorded time of day timecode so there is a lot of timecode breaks so maybe when i consolidated using 50 frame handles it went past a timecode break on some clips and took in alot more media.
    going to try giving less handles and see if that works...
  • Thu, May 8 2008 10:50 AM In reply to
    • cluas
    • Posts 9
    • Points 75
     I seem to have fixed it! i tried a number of things so I am unsure which is the solution but here's what I did;
    i started from scratch again, deleted all consolidated clips, then I deleted the msm files from the omfi media files folder, rescanned the drives, reopened media composer, went through the sequences and lifted out all black space in between clips, (there was 1 or 2 match frame edits on the filler here and there)
    I then split up the sequence, taking tacks 1 and 2 and consolidating them with 10 frame handles, tracks 3 and 4 with 20 frame handles and all the music tracks 5-8 with 50 frame handles.
    all together these are now just a little over 700mb as have all the other sequences.
    no clue what did it, maybe a combination, but it worked..
    thanks for help. hope this helps someone too.
