Latest post Wed, May 7 2008 8:56 AM by Blue Crow. 1 replies.
Page 1 of 1 (2 items)
  • Tue, May 6 2008 5:25 AM
    • tlongo
    • Posts 3
    • Points 45
    Embarrassed [:$] A media composer project being cut on Mac and PC sharing media with UNITY
    The tech support I have getting our to go package ready for location says that we might and will have problems with having a PC and a Mac platform both accessing media from the UNITY.  The editor I am working for says he has never had problems with this configuration. We are cutting using Adrenaline and I am not sure of what version of any software we are using...does anyone have a heads up on what might be a problem?  Thanks, Teri
  • Wed, May 7 2008 8:56 AM In reply to
    • Blue Crow
    • Joined on Mon, Oct 23 2006
    • Posts 409
    • Points 5,015
    Re: A media composer project being cut on Mac and PC sharing media with UNITY
    You shouldn't have problems with the actual media. If the Mac is is using Sound Designer II audio files the Pc won't read them but you should have a choice between Sound Designer II and AIFF-C and Wave so that should be ok.
    Any titles used would have to be recreated if you moved a sequence between systems and you should check fonts as they might not the be them exactly same. You'll be asked to use a substitute if it's not on the other system.
    What did the support guys say exaclty was the problem ?
    xw8200 Avid Adrenaline version 2.7 , xw8000 Symphony 5.5.7 , Symphony Nitris dual boot DS versions 1.7.7 & 8.4 Lanshare Lp 4.2.3 , ISIS 1.4 [view my complete system specs]
