Latest post Tue, May 6 2008 4:21 AM by jasonsaro. 1 replies.
Page 1 of 1 (2 items)
  • Mon, May 5 2008 10:24 PM
    1:1 uncompressed om ethernet Lanshre?
    can i run 1:1 on ethernet lanshre? i need 2 streams on 2 editing clients...
    connected on 1Gb conection using the Asante 35160 T switch,
    will it work?
     Dori
    spec:
    Avid Unity Lanshare EX3 - 4 TB
    WIN 2000 Server
    Version 4.1.1
  • Tue, May 6 2008 4:21 AM In reply to
    • jasonsaro
    • Philadelphia
    • Posts 438
    • Points 5,295
    Re: 1:1 uncompressed om ethernet Lanshre?
    First off, gigabit from the chassis to the switch.  10/100 from the switch to the client.  No gigabit from the chassis to the switch, to the client, with LanShare EX.  Now, with this switch, it has 4 1000gb ports, are your clients plugged into them?  If so and your getting 1000mb a sec, first ive heard, ive always known that its always 10?100 to the client on Lanshare EX.
    Ive run 2:1 on clients, ethernet, no issues, in a pinch, never had an issue.  The clients were 4 MCA 2.x when i was running it.  Not the "avid approved way" of fiber, but it worked.  Try it, worst that could happen is that you have AECIFS read stream errors and maybe you crash the file manager.  Look in the 4.1.1 readme, there should be bandwidth req. listed and tested configs.
    Now, this is from the EX readme on Setup from 3.1, i doubt it would have changed since then, seeing they are still using the same asante switch.
    LANserver EX Ethernet Attached Clients
    The following sections describe the Avid Composer Products clients you
    can attach to a LANshare workgroup through the Ethernet switch.
    These clients can use the following video resolutions:
    • 4:1s or lower – up to 10 dual-stream clients or up to 20 single-stream
    clients
    • 10:1 or lower – up to 10 dual-stream clients or up to 20 single-stream
    clients
    • 10:1m or lower – up to 6 four-stream clients or up to 5 nine-stream
    clients
    • DV 25 – up to 20 single-stream clients
    LANserver EX Fibre Channel Attached Clients
    can attach to a LANshare workgroup through the Fibre Channel adapter
    boards.
    • 1:1 – 1 dual-stream client
    • 2:1 or lower – up to 4 dual-stream clients
    • DV 25 – up to 6 dual-stream clients or up to 3 four-stream clients
    (NewsCutter XP clients only)
    • DV 25 (using SDTI) – up to 3 four-stream clients performing digitize
    or up to 4 four-stream clients performing playback (NewsCutter XP
    clients only)
    • DV 50 – up to 6 dual-stream clients (NewsCutter XP clients only)
    Jay
    4 MCA's ver. 2.8 1 MC Meridian Composer 1000 Ver 12.1.1 3 MC Mojo 2.8 1 Xpress Pro Mojo 5.2 1 LanShare 6TB Ver. 4.1.5 [view my complete system specs]
    "What we want is a smashing theme of mythic grandeur" - Stanley Kubrick Favorite Avid Term "JBOD" - Just a Bunch Of Disks _______________ Jason Saro SR. Avid Editor / Unity Admin. - Nancy Glass Productions jason@nancyglassproductions.com
