Latest post Fri, May 9 2008 8:39 PM by freelancer. 4 replies.
  • Sun, May 4 2008 5:40 PM
    • zobo
    • Posts 3
    • Points 45
    blank white pop up freezes playing sequence, avid crash. intermittent but common
    when i try to play the sequence an empty white rectangular pop up window appears. the sequence stops playing and avid crashes. doesn't happen every time or everywhere on the sequence. a couple of times, a few clips became an unusual bright red colour, I deleted them in the hope it would help. but the problem remains. intermittent, but more often than not.
    thanks for advice!
    using mac g4 powerbook running osx 10.4.11, software is avid express dv 4.6
  • Sun, May 4 2008 6:57 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 15,836
    • Points 201,220
    Re: blank white pop up freezes playing sequence, avid crash. intermittent but common
    You are way out of spec. 4.6 is not qualified for 10.4.11. You need to be running 10.3.9 at the very latest.
  • Sun, May 4 2008 10:18 PM In reply to
    • zobo
    • Posts 3
    • Points 45
    thanks for the tip.
    I'm a film maker been using this set up for about 3 years, mostly trouble free.
    not being techie, downgrades and upgrades and that sort of thing tend to leave me rather cold, and often with a non functional something or other. so given that this is something that has only lately come up, is there definitiely no more immediate likely cause and solution?
    thanks
  • Sun, May 4 2008 10:32 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 15,836
    • Points 201,220
    Well, you can't have been using THAT particular setup for three years as that OS is less than 3 months old.
    What's happening is, because your OS isn't supported, you can't see the error message that's popping up.
    Not much else I can suggest other than loading the proper OS.
  • Fri, May 9 2008 8:39 PM In reply to
    • freelancer
    • Joined on Wed, Dec 13 2006
    • Posts 6
    • Points 65
    I have sent you an email about sending sequences via email! Or should I just ask you on this forum instead?
