Latest post Sun, May 4 2008 7:02 PM by hbrock. 6 replies.
Page 1 of 1 (7 items)
  • Sun, May 4 2008 8:29 AM
    • BMW
    • Posts 40
    • Points 570
    out putting a mpeg2 file.
    Is there away to out put a quicktime file with an mpeg2 compression, using a mac?
  • Sun, May 4 2008 8:33 AM In reply to
    • camoscato
    • Posts 4,432
    • Points 52,925
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    Re: out putting a mpeg2 file.
    No.  The easiest way is to export a Quicktime reference movie and use a third party encoder (Squeeze or Procoder) on the same system to encode it to MPEG2.
    good luck,
    Carl
    MC 3.0, HP dv9605ea, Vista Home Premium, AMD Athlon 1.8 GHz, 2 GB RAM, nVidia GeForce 7150M, Conexant HD Audio [view my complete system specs]
  • Sun, May 4 2008 8:34 AM In reply to
    • BMW
    • Posts 40
    • Points 570
    Can't output  a ref, I footage is HD.
  • Sun, May 4 2008 8:41 AM In reply to
    • camoscato
    • Posts 4,432
    • Points 52,925
      Moderator: Meridien
    Then output a full QT movie.
    good luck,
    Carl
  • Sun, May 4 2008 8:48 AM In reply to
    • BMW
    • Posts 40
    • Points 570
    What compressor, if any would you use on the QT output.  The footage is DVCpro HD 720p 24fps.  Would out put with no compression and set the size to 1920/1080? our put the DVCpro comression on it?
  • Sun, May 4 2008 9:24 AM In reply to
    • camoscato
    • Posts 4,432
    • Points 52,925
      Moderator: Meridien
    What's the MPEG2 going to be used for?  DVD?  Broadcast?  Something else?
    good luck,
    Carl
  • Sun, May 4 2008 7:02 PM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 2,714
    • Points 31,085
    Put it out in the same format that it's currently in to avoid any more transcoding than necessary.  In your case that would appear to be 720p/24 DVCPro HD.
    MacPro, MacBook Pro and a Cube. The Cube doesn't do much but it looks cool. [view my complete system specs]
