Latest post Sat, May 24 2008 4:38 PM by Guywithcat. 4 replies.
  • Sun, May 4 2008 12:18 AM
    • cptvideo
    • Joined on Mon, Mar 6 2006
    • Posts 1
    • Points 35
    pretty basic Dv resolution question
    I understand that the DV specification is for a file of 720x480 pixels, in either a 4:3 or a 16:9 frame.
    Why then, when I render-out a test pattern from After Effects at 720x405 pixels and import that into an Xpress DV 16:9 sequence, does it look correct?  Shouldn’t the 405-pixel height of the AE output get stretched into a 480-pixel-high DV frame in Xpress DV?
    Another way of asking this question is why does a 720x480 output from AE look stretched in an Avid 16:9 window?
    thanks, Craig Umanoff
  • Sun, May 4 2008 2:04 AM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,289
    • Points 168,655
      Moderator: MCA Mac
    Re: pretty basic Dv resolution question
    If you are importing in using the 601 aspect ratio, I would think the 405 frame should look stretched (albeit very slightly). The only way it wouldn't is if you chose one of the maintain options.
  • Sun, May 4 2008 11:33 AM In reply to
    Because the Avid unfortunately is uncapable of interpreting square pixels correctly when importing into a 16x9 project. It will always convert between square pixels and 4x3. This is a bad thing. The way around it is to create 16x9 graphics in widescreen in square pixels, then resize&squeeze into 601.
    Symphony Nitris 3.0 on 2xquad core XW8400/4(??)GB | MC 3.0 on dual core XW8400/3GB | Mojo SDI | Unity Lanshare 4.23 fibre | MC 3.0 on MacBook 2.16/2.5GB... [view my complete system specs]
  • Fri, May 23 2008 11:13 AM In reply to
    • Wm.Busby
    • LA, Cali
    • Posts 239
    • Points 2,835
    I think I read in the old Xpress DV FAQ years ago that 16x9 DV is spec'd to 853x480, not 720x405. Not that it may make a difference or not :)
    Dell Precision 330, 2.6ghz, 1gig ram, 80 gig sys drive, 1TB media, SB Audigy, ADS Pyro, DSR-11, MAudio BX5's, Power Reach Duo KVM, dual Sammies, Win2K... [view my complete system specs]
    Forum etiquette rule #1: FILL OUT SYSTEM SPECS IN PROFILE! :)
  • Sat, May 24 2008 4:38 PM In reply to
     it probably is a teeny bit stretched. Find something perfectly circular and look it on screen... perhaps you can the stretch there. if it not stretched I am clueless (as usual)
    HP XW8400 Dual, Dual Core; 4 TB Dulce RAID 5; 3GB Ram; XPRO (latest version); AJHD 1400; HP XW8400 Dual, Dual Core; 7 TB G-TECH RAID 5 (2 encl); 3GB... [view my complete system specs]
    Eating is a moral act. If you eat meat from factory farms, you partake in a system of cruelty, violence and evil. Always take sides. To be passive empowers the oppressor.
