Latest post Fri, May 2 2008 9:20 PM by ceffoavid. 1 replies.
Page 1 of 1 (2 items)
  • Fri, May 2 2008 8:29 PM
    No audio from some clips
    I went through some drive problems and had to copy all my media from one drive to another and then back again. Everything is intact except there are a lot of audio clips that are silent. If I go to the first frame of the audio clip in the timeline and do a match frame, it brings up the source slip in the source monitor and it plays fine there. But the same clips in the timeline make no sound. If I match frame it and then edit it into the timeline, then it works.
    I have a lot of clips like this in the timeline and they all have some EQ and level adjustments. When I replace the clips I lose those settings. I tried relinking but nothing relinked. Obviously the media is not offline or it would not show up in a martch frame in th source monitor.
    Is there any other way I can get the audio back without replacing all the clips?
    [EDIT]
    I had an earlier version of the timeline and the audio is all fine on that one.
    MC 2.8.1 Dell 670, Dual Xeon 3.6 GHz, Win XP SP2, 3GB RAM (6x512) QT 7.2, nVidia Quadro FX3500/256MB, 8x500GB RAID 5 controlled by 3Ware 9650SE-8LPML in... [view my complete system specs]
  • Fri, May 2 2008 9:20 PM In reply to
    • ceffoavid
    • Joined on Thu, Jan 17 2008
    • Posts 104
    • Points 1,180
    Re: No audio from some clips
    sounds like sequence corruption.  What if you cut that sequence into a new sequence?
    Avid DS Artist and Tech Avid MC and Symphony Editor and Tech Here are some video's I edited with Avid DS Nitris. http://myspacetv.com/index.cfm?fuseaction=vids.individual&videoid=4525133 http://myspacetv.com/index.cfm?fuseaction=vids.individual&videoid=6118459 http://myspacetv.com/index.cfm?fuseaction=vids.individual&videoid=8204314
