Latest post Sun, May 4 2008 11:55 PM by jwrl. 10 replies.
Page 1 of 1 (11 items)
  • Fri, May 2 2008 8:10 PM
    Removed site settings, froze, then big trouble
    I was having a minor problem, I don't even ermember what it was now! I thought it might be solved by trashing some settings so I removed MC State and Site Settings. Relaunched Avid but it hung. Would not respond to repeated attempts at CTRL-ALT-DEL. SO I manually powered down. Then Windows would not start, not even in safe mode. It hung when trying to load a Promise driver.. a long message ending with "System32\DRIVERS\dontgo.sys". Apparently something was corrupted during the manual power cycle.
    Eventually I ended up doing a repair/reinstall of Windows and now everything appears to be back to normal.
    Of all programs I have ever run, Avid seems to be the least responsive to CTRL-ALT-DEL. I hate having to manualy power down, but sometimes it is the only way. Is this your experience? Are there any ways to avoid this kind of thing?
    MC 2.8.1 Dell 670, Dual Xeon 3.6 GHz, Win XP SP2, 3GB RAM (6x512) QT 7.2, nVidia Quadro FX3500/256MB, 8x500GB RAID 5 controlled by 3Ware 9650SE-8LPML in... [view my complete system specs]
  • Fri, May 2 2008 9:22 PM In reply to
    • ceffoavid
    • Joined on Thu, Jan 17 2008
    • Posts 104
    • Points 1,180
    Re: Removed site settings, froze, then big trouble
    No.
    Avid DS Artist and Tech Avid MC and Symphony Editor and Tech Here are some video's I edited with Avid DS Nitris. http://myspacetv.com/index.cfm?fuseaction=vids.individual&videoid=4525133 http://myspacetv.com/index.cfm?fuseaction=vids.individual&videoid=6118459 http://myspacetv.com/index.cfm?fuseaction=vids.individual&videoid=8204314
  • Sat, May 3 2008 7:12 PM In reply to
    • mcabery
    • Posts 20
    • Points 270
    I find that if any given program is taking too long to shut down after using task manager to shut it off I go into the process tab and shut down dumpprep (or some similar name) the programs generally shut down right away after that.
    DFI X38 T2R MB, Intel 6850 Dual Core 3.0Ghz Conroe, 2 GB RAM, Nvidia 1500, SATA Raid 5, Win XP, On board firewire plus a SIIG PCI card. [view my complete system specs]
  • Sat, May 3 2008 10:57 PM In reply to
    Great Tip I will have to try it sometime.
  • Sat, May 3 2008 11:40 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 5,185
    • Points 61,950
    mcabery:
    I find I always have to use this procedure when Avid freezes or crashes.
  • Sun, May 4 2008 1:31 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 3,220
    • Points 36,950
    Avid writes a logfile reporting program status when you have an illegal exit either by crashing or forcing a quit from task manager.  Shutting that process down aborts the operation.  It means that it will not be possible to debug the issue should you wish to.
    One cause of slow writes to the logfile is that it's become too big.  I'm at home so I don't know where they're written to currently, but you can speed up forced exits by moving your logfiles to a backup folder.  New smaller, faster ones will then be written as required.
    MC 3.0 - Gigabyte GA-X38-DQ6 mobo - Intel core 2 Extreme Q6850 3 GHz - nVidia Quadro 1700 - 4 Gbyte mem - Internal 4 Tb SATA II 4-way RAID 5 array - Pyro... [view my complete system specs]
  • Sun, May 4 2008 1:40 AM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 5,185
    • Points 61,950
     jwrl, when you get a chance would you please post the path. I'd like to try that on Monday.
  • Sun, May 4 2008 1:58 AM In reply to
    • jwrl
    • Posts 3,220
    • Points 36,950
    Will do.
  • Sun, May 4 2008 2:08 AM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 12,710
    • Points 161,440
      Moderator: MCA Mac
    C:\Program Files\Avid\AvidApplicationName\ You are looking for the folder:  "AvidFatalErrorReports"
  • Sun, May 4 2008 2:15 AM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 5,185
    • Points 61,950
     Thanks BLKDOG, that's where I'd expect to find them. Just wasn't sure whether or not they had been "relocated".
  • Sun, May 4 2008 11:55 PM In reply to
    • jwrl
    • Posts 3,220
    • Points 36,950
    Ditto
