Latest post Sat, May 3 2008 10:44 PM by editz. 6 replies.
Page 1 of 1 (7 items)
  • Thu, May 1 2008 7:47 PM
    • CR8VDO
    • Joined on Mon, Mar 31 2008
    • St. Louis
    • Posts 52
    • Points 800
    HELP! Help doesn't work??
    Selecting ANYTHING under the Help drop down menu cause AVid to crash with a runtime error.  Can't access help files or ANYTHING listed under "help".
    Operating System Windows Vista Ultimate (build 6000) 2.40 gigahertz Intel Core2 Quad 64 kilobyte primary memory cache 4096 kilobyte secondary memory cache... [view my complete system specs]
  • Thu, May 1 2008 8:13 PM In reply to
    • sasfog
    • Bristol United Kingdom
    • Posts 166
    • Points 1,985
    Re: HELP! Help doesn't work??
     Are you running IE7? I believe it can cause this problem.
    Graham
    Pentium 4 3.4 GHZ ASUS P4P800 2GB DDR SDRAM PC 3200 80GB 7200RPM Hard Drive NVIDIA GEFORCE FX5200 128MB AGP Graphics MC 2.8 with Mojo (not SDI) Sony... [view my complete system specs]
  • Thu, May 1 2008 8:41 PM In reply to
    I have the same problem. Every time I click on help, avid crashed. And I dont have IE7 or anthing like that on my rig. My work around to that is if you go in to your start menue and programs and then Avid. You can lunch Avid help from there.
    Intel Xeon E5345 Quad 2.33GHz - TyanS2696 MotherBoard - 4Gb Quad Channel DDR2 667 Ram - Nvidia Quadro FX 540 - 160GB (boot drive) 1.2 TB Raid 0 (4x320... [view my complete system specs]
  • Thu, May 1 2008 8:44 PM In reply to
    What version are you guys running?
    MacPro Symphony Nitris DX (v3.0), MacPro MCA HD (v3.0), Mac Meridien (v12.1.2), Unity LanShare EX (v4.1.6) [view my complete system specs]
  • Sat, May 3 2008 10:48 AM In reply to
    • Biggles
    • Posts 27
    • Points 315
     I too have this problem. I have just upgraded from Xpress Pro to Media Composer and it has happened on both MC2.8 and 2.8.3. I have a certified Dell M65 running IE6, and agree you can work around it... but its a bit annoying.
    Biggles
    Avid MC 2.83 Dell M65 2 gig ram [view my complete system specs]
  • Sat, May 3 2008 8:18 PM In reply to
    • Biggles
    • Posts 27
    • Points 315
     Sorry I should have added... has anyone managed to work out a solution for this?
    Cheers
    Biggles
  • Sat, May 3 2008 10:44 PM In reply to
    • editz
    • Eugene, Oregon
    • Posts 64
    • Points 775
    I had posted about this problem a couple of weeks ago.  Thought I had it licked based upon the advice I'd received here, but it seems to have come back.  My current workaround is to put a shortcut to the Help application on my desktop and remember to access it from there to keep MCA from crashing.
    MCA 2.2.10 XW8000 dual 3.0GHz, 2GB RAM, NVIDIA 980 [view my complete system specs]
