Latest post Fri, May 2 2008 3:28 PM by sasfog. 14 replies.
Page 1 of 1 (15 items)
  • Thu, May 1 2008 6:02 PM
    Posting same thread in 2 forums?
    I know that is probably against the forum rules. But I was wondering, with XPressPro and MC so closely related, and with the XPress Pro forum still 3 times larger than the MC forum, don't I stand a chance of missing some possible replies by posting only in the MC forum? Or does everyone hop back and forth like I do anyway? Can I post in MC and then post in XPressPro with a link to my MC post? Or is that getting too complicated?
    Just trying to maximize the possibilities for replies, but I don't want to mess up the forum.
    MC 2.8.1 Dell 670, Dual Xeon 3.6 GHz, Win XP SP2, 3GB RAM (6x512) QT 7.2, nVidia Quadro FX3500/256MB, 8x500GB RAID 5 controlled by 3Ware 9650SE-8LPML in... [view my complete system specs]
  • Thu, May 1 2008 6:05 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,862
    • Points 175,670
    Re: Posting same thread in 2 forums?
    No. Please do not double post. The moderators will move your thread if it is not getting  the proper attention. Since your thread appears in the Active column to the right, all users can see your post.
  • Thu, May 1 2008 6:06 PM In reply to
    • camoscato
    • Posts 4,686
    • Points 55,850
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    If your post is MC related, post it in the MC forum.  It's not as active as the XP forum, but it's still pretty active, and I can't speak for everyone, but I check through all the forums I know something about rather than just sticking to one.  Also, as more and more people migrate to MC, it will eventually be as active as the XP forum.
    In any case, don't post the same problem in two forums, because you'll have different people helping you in two places, and it'll be hard for us to figure out what troubleshooting steps you've already tried, or if your problem is solved.
    If you're not getting a response to a thread, just reply to it with the word "bump" to move it back to the top and let everyone know you still need help.
    good luck,
    Carl
  • Thu, May 1 2008 6:12 PM In reply to
    camoscato:
    I've noticed this, and I do it myself... makes sense.
  • Thu, May 1 2008 6:16 PM In reply to
    BLKDOG:
    Thanks for pointing that out. I spend almost all my time in either the MC or XPressPro forum and have never paid much attention to that page. Hadn't even noticed the "active" listing before. I will definitely check there more often now that I'm aware of it!
  • Thu, May 1 2008 6:23 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,862
    • Points 175,670
    Yeah, it's supposed to be on every page but, when the forum switched over, we lost it on the product pages. Avid says it will come back though.
  • Fri, May 2 2008 12:27 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 3,491
    • Points 40,375
    I'm not sure that the Xpress Pro forum is still the more active.  I check both, and today when I first started up there was a page and a half of posts on this forum and just over half a page on Xpress Pro-PC.  And it's been that way for at least two weeks.
  • Fri, May 2 2008 1:09 AM In reply to
    I have one bookmark...  http://community.avid.com/forums/TopicsActive.aspx?ForumID=-1  Takes me to "Active Topics" and I can quickly scan the subject lines and because I'm using Firefox I can right-click and choose "open in new tab" (same goes for IE7)  Then I just hop through the tabs....  makes browsing the forum and staying on top of things so much easier.
    MacPro dual 2.66GHz 2GB RAM NVIDIA GeForce 7300 GT Storage: 2TB G-Speed eS with controller card 3x500GB Hitachi SATA-II internals various external... [view my complete system specs]
  • Fri, May 2 2008 2:00 PM In reply to
    • daktulus
    • Posts 376
    • Points 5,035
    "because you'll have different people helping you in two places" would be very helpful wouldn´t it? Most people just look in one forum (Xpress PC). So to get the broadest bandwidth of opinions (MC users sometimes have a different approach), it makes sense to post in another forum, especially if you dont get an answer. A more open view and a better handling of double posts, if you dont get an answer in one forum would make sense. Too many threads have been locked or deleted imprudently, not to the benefit of the user. We are here to exchange information and sometimes help is needed very quickly (you all have been in this situation), in these situations the moderators should handle double posts with ease (if you dont get an answer in one forum).
    Dell650, 2.8Ghz, 3 GB RAM, FX500, 5 SCSI HDDs, Mojo. Dell Precision M90, Core2Duo 2.16Ghz, FX1500, SATA 7200rpm Media Composer 3.0 [view my complete system specs]
  • Fri, May 2 2008 2:09 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,862
    • Points 175,670
    And we do. Bottom line. Double posting is not permitted. If you post in two forums, we will delete one of them. The reason is simple, this is not only a forum for discussion, it  is also an ongoing database of answers for user to search and find solutions. To that end, we try to keep the information as succinct as possible and in as close to one location as possible in order to follow the progress of a problem. That way, not only other users, but Avid support as well can find and follow the progress on a particular issue.
    It isn't really up for a debate. This is the direction we've been given as to how to manage the forums so that is what we have to do.
  • Fri, May 2 2008 2:15 PM In reply to
    • daktulus
    • Posts 376
    • Points 5,035
    Who gave the direction?
  • Fri, May 2 2008 2:21 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,862
    • Points 175,670
    Who do you think?
  • Fri, May 2 2008 2:22 PM In reply to
    • camoscato
    • Posts 4,686
    • Points 55,850
      Moderator: Meridien
    daktulus:
    In theory it would, but in practice what results is two sets of people working on the same problem independently without collaboration.  Thus, neither one knows what troubleshooting steps have already been tried by the other, or even if the problem has already been solved.
    The original poster often only pays attention to the thread that is getting the most replies, thus leaving other users wondering if their posts are being read or not, and leading to frustration when they realize they've been trying to help someone who is no longer paying attention.
    So we keep it simple: one post per problem.
    good luck,
    Carl
  • Fri, May 2 2008 2:24 PM In reply to
    Seems like the key to this is using the "active threads" list... but it would be nice if it was a longer list, they tend to drop off pretty fast which IMHO could cause a lot of bumping.
  • Fri, May 2 2008 3:28 PM In reply to
    • sasfog
    • Bristol United Kingdom
    • Posts 170
    • Points 2,025
     I agree, it is a tricky one. It is exacerbated by the sub divisions for PC or MAC, not sure what the answer is, I agree with the Moderators in that I wouldn't want the same thread appearing in half a dozen different places but you do wander if all the people that could assist with a query are actually aware of your query.
    I'm off for the weekend, take care all Smile
    Pentium 4 3.4 GHZ ASUS P4P800 2GB DDR SDRAM PC 3200 80GB 7200RPM Hard Drive NVIDIA GEFORCE FX5200 128MB AGP Graphics MC 2.8 with Mojo (not SDI) Sony... [view my complete system specs]
