Latest post Fri, May 2 2008 8:30 AM by jwrl. 3 replies.
  • Thu, May 1 2008 5:48 PM
    • JamesG
    • Posts 76
    • Points 970
    transcoding hd to dv
    Here's a weird one:
    When I transcode dnx hd 185 x progressive material (shot on HD CAM SR at 60fps) to DV 25 in a 25i project it makes an interlaced clip with 2 different fields for each frame!!!
    How can that be?  And more importantly, can I stop it doing that?
  • Fri, May 2 2008 12:22 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 3,333
    • Points 38,325
    Re: transcoding hd to dv
    You can't.  NTSC is an interlaced format.  Downconverting to SD will always give you an interlaced result.
  • Fri, May 2 2008 12:45 AM In reply to
    • JamesG
    • Posts 76
    • Points 970
    Actually I'm in PAL land but maybe the answer still applies..?
  • Fri, May 2 2008 8:30 AM In reply to
    • jwrl
    • Posts 3,333
    • Points 38,325
    Sure does.
