Hi -
I have recently invested in a Canon HV20- and have recorded in HD, 24P. How can I capture this in AVID, 5.7+?
Glenn
You can't. Avid doesn't support Canon's 24F format. Or didn't, last time I checked. 1080/60i HDV should work assuming your hardware meets the System Requirements (Dual G5 or Intel Mac).
hbrock: You can't. Avid doesn't support Canon's 24F format. Or didn't, last time I checked. 1080/60i HDV should work assuming your hardware meets the System Requirements (Dual G5 or Intel Mac).
Thanks for the feedback!!!! I have a Mac Book Pro 17'', which is an Intel Mac (I believe). System requirements should meet.
I think I once converted to 24p in an AVID project, or am I dreaming?
Thanks Again!!!
You've got to get the material into the Avid first. Try capturing both 24F and 60i material into a HDV project and let us know which one(s) work.
hbrock: You've got to get the material into the Avid first. Try capturing both 24F and 60i material into a HDV project and let us know which one(s) work.
When I try to capture, I get the following errors -
SELECTING V TRACK -- Exception: Operation not supported,filename:creating39SELECTING ANY A TRACK -- Exception : ADM_DIO_ERROR_OCCURRED , DIOerr:PMDIO_InputMode:Start - driver error: - FTStatus Code _FT_StartLinkFailed - FlamethrowerOHCICaptureLink:StartLink - Failed to start stream
What is causing these errors?
