Latest post Fri, May 9 2008 8:45 PM by mrster. 4 replies.
  • Wed, Apr 30 2008 10:53 PM
    • mrster
    • Joined on Wed, Apr 30 2008
    • Posts 3
    • Points 35
    Avid Xpress 5.7+ and Capturing 24p HD
     Hi -
    I have recently invested in a Canon HV20- and have recorded in HD, 24P. How can I capture this in AVID, 5.7+?
    Glenn
  • Thu, May 1 2008 2:57 AM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 2,737
    • Points 31,300
    Re: Avid Xpress 5.7+ and Capturing 24p HD
    You can't.  Avid doesn't support Canon's 24F format.  Or didn't, last time I checked.  1080/60i HDV should work assuming your hardware meets the System Requirements (Dual G5 or Intel Mac).
    MacPro, MacBook Pro and a Cube. The Cube doesn't do much but it looks cool. [view my complete system specs]
  • Thu, May 1 2008 4:54 PM In reply to
    • mrster
    • Posts 3
    • Points 35
    hbrock:
    Thanks for the feedback!!!! I have a Mac Book Pro 17'', which is an Intel Mac (I believe). System requirements should meet.
    I think I once converted to 24p in an AVID project, or am I dreaming?
    Thanks Again!!!
  • Thu, May 1 2008 5:50 PM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 2,737
    • Points 31,300
    You've got to get the material into the Avid first.  Try capturing both 24F and 60i material into a HDV project and let us know which one(s) work.
  • Fri, May 9 2008 8:45 PM In reply to
    • mrster
    • Posts 3
    • Points 35
    hbrock:
    When I try to capture, I get the following errors -
    SELECTING V TRACK -- Exception: Operation not supported,filename:creating39
    SELECTING ANY A TRACK -- Exception : ADM_DIO_ERROR_OCCURRED , DIOerr:PMDIO_InputMode:Start - driver error: - FTStatus Code _FT_StartLinkFailed - FlamethrowerOHCICaptureLink:StartLink - Failed to start stream
    What is causing these errors?
