Latest post Wed, Apr 30 2008 9:50 PM by hbrock. 9 replies.
Page 1 of 1 (10 items)
  • Wed, Apr 30 2008 3:35 AM
    • elimuel
    • Joined on Sun, Mar 19 2006
    • Austin, Texas
    • Posts 14
    • Points 160
    Which is the best upgrade?
    i have a MacBook, Mac OS X 2.1 GHz Intel Core 2 Duo 1 G Memory.  with avid new update for mac and the soon xpress pro going away, i want to up grade but don't know if upgrading to the v5.8 or the media composer version.  i notice that there is no good dvd program because sonic dvdit is pc only and fcp you have to buy the full version. (1) is there a dvd software that i can use to burn after i edit my project? is it best to just stay with the v5.8 for now and upgrade to media composer later.  the down load does not include the 3rd party.  the full version has 3rd party but sonic dvdit is pc only. in comparison which would be best?
    MacBook Pro Max OS X 2.1 GHz Intel Core 2Duo 1 GB Memory DDR2 SDRAM [view my complete system specs]
  • Wed, Apr 30 2008 5:51 AM In reply to
    • curiosity
    • Boulder, CO
    • Posts 611
    • Points 7,735
    Re: Which is the best upgrade?
    At this point you'd be better off upgrading to MC.
    The only alternative to FCS - DVDSP is Adobe's Encore for Mac. But this is bundled together with Premiere - so you don't really have any other options (iDVD isn't terrible, its just kind of mediocre).
    Macintosh: Intel 2.8GHz(8C - 2007), 4GB RAM, SUNIX [view my complete system specs]
  • Wed, Apr 30 2008 6:12 AM In reply to
    • elimuel
    • Austin, Texas
    • Posts 14
    • Points 160
    thanks, i think your right the only problem i discovered is mc does not support leopard right now, so looks like i may have to wait until the release.  yes idvd is not bad but i can not remove the menu so i can do a quick start. it is good for small project and that's it.  well i just have to wait till a new release for leopard. thanks
  • Wed, Apr 30 2008 6:27 AM In reply to
    • curiosity
    • Boulder, CO
    • Posts 611
    • Points 7,735
    elimuel:
    It isn't officially supported but plenty of people are running it on Leopard right now (I'm one of them)
    Yes you can (its called a "One-Step DVD" in iDVD's terms) In iDVD 5 or later:
    1. Open iDVD
    2. Create a New Project
    3. Go to "File > One Step DVD from File"
    4. Navigate to your QT export from Avid.
    5. Burn the disk
    That will make an autostart DVD with no menus.
  • Wed, Apr 30 2008 7:01 AM In reply to
    • elimuel
    • Austin, Texas
    • Posts 14
    • Points 160
    curiosity:
    elimuel:
    1. Open iDVD
    5. Burn the disk
    will need to figure out the idvd thing because my One step DVD is grayed out but will look at the mc upgrade thanks
  • Wed, Apr 30 2008 7:21 AM In reply to
    • elimuel
    • Austin, Texas
    • Posts 14
    • Points 160
    hey curiosity i figured  out the one step dvd thanks so much. now i can finish my project
  • Wed, Apr 30 2008 12:01 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,244
    • Points 168,010
      Moderator: MCA Mac
    One thing to keep in mind, Avid software is not supported on the Macbooks. Just MacBook Pro.
  • Wed, Apr 30 2008 2:22 PM In reply to
    • elimuel
    • Austin, Texas
    • Posts 14
    • Points 160
    thanks, i will keep that in mind, unlike fcp which does not take much  to run [i am working with fcpx] avid is different.  i may go ahead and buy it so that when i do upgrade to macbook pro i will be in good shape.
  • Wed, Apr 30 2008 6:06 PM In reply to
    • matcas
    • Posts 86
    • Points 1,045
    Also toast work's great
    G5 dual 2.0 3.5 gigs of ram mojo Mc 3.0.1 [view my complete system specs]
    Freedom of speech its fair for all
  • Wed, Apr 30 2008 9:50 PM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 2,736
    • Points 31,295
    FYI, FCP has similar System Requirements as Avid's and won't run on a MacBook while FCP Express will work on CPUs with built-in Intel Graphics chips.
    MacPro, MacBook Pro and a Cube. The Cube doesn't do much but it looks cool. [view my complete system specs]
