Latest post Thu, May 1 2008 8:32 PM by Bill Nelson. 3 replies.
  • Wed, Apr 30 2008 3:20 AM
    • Bill Nelson
    • West Coast
    • Posts 519
    • Points 5,955
    Title Tool Fury
    tried to edit a title from an existing project.
    Just crashed clear back to the Cascading Curtain of Multi-Language Greyness as I attempted to do so. Seems it no longer could recognize a font I'd been using in that sequence for the tag for years.  Admittedly an ugly font, I do as I'm told.
    Any thoughts on how to proceed?  Checked with FontBook.  OpenType font is active.
    MC v3.0.5 thru SDI Mojo, OS 10.5.5, QT 7.5.5, on Intel G-5 Octo 2.8 w/8 gig RAM, 2Tb internal RAID volume, 4TB CalDigit HDOne RAID, 30"Display, NVIDIA... [view my complete system specs]
  • Wed, Apr 30 2008 6:31 AM In reply to
    • BlueMac
    • Joined on Wed, Apr 30 2008
    • Posts 1
    • Points 5
    Re: Title Tool Fury
    Hello Bill,
    Not sure if it will affect your title tool issue, but I note that the version of QuickTime you are using is 7.31, but the Read Me doc on SW Media Composer only certifies version 7.2 of QuickTime.
    Does the bug repeat every time you try to edit the title?
    Do other titles cause the same problem?
    Have you done the standard stuff for corruptions?  (eg. delete MC State, Site Settings, Site Attributes, repair permissions or run a disk utility like Disk Warrior?))
    Have you tried using a new set of user settings?
    How do you enter the title edit?  (from Timeline in Effect Edit, from a bin?)
    Good Luck,
    BlueMac
  • Wed, Apr 30 2008 9:37 PM In reply to
    • kutter
    • Joined on Sun, Jun 17 2007
    • Phoenix, Arizona
    • Posts 63
    • Points 765
    Re: Title Tool Fury
    Can you start a new project, open the bin with the title you want to recreate, copy the the title to a new sequence and then recreate?
    Also, according to  http://community.avid.com/forums/t/44210.aspx
    your version of QT shoud work fine.
    Kent
    Symphony Nitris 1.8.2 Kreiger Post MCSoft Apple G5 dual 2.0 O. S. x 10.4.11 4gigs RAM QuickTime 7.3 Mojo SDI MCSoft Dell M.... [view my complete system specs]
    Kent Kreiger
    ACI
    Metropolitan Post
    http://metroav.tv
  • Thu, May 1 2008 8:32 PM In reply to
    • Bill Nelson
    • West Coast
    • Posts 519
    • Points 5,955
    Re: Title Tool Fury
    good idea on the trashing things, new project route...  well done.
