Latest post Thu, May 1 2008 11:57 PM by daktulus. 16 replies.
  • Tue, Apr 29 2008 2:02 PM
    • daktulus
    • Posts 376
    • Points 5,035
    What is the most commonly used PAL QT codec?
    The Quicktime and AVI films I´m making will be integrated into a Power Point presentation and must be accessable to most amateur users: which is the most commonly used PAL 4:3 QT codec, which AVI codec can be played back by everyone (PC + Mac) with the best possible quality
    Dell650, 2.8Ghz, 3 GB RAM, FX500, 5 SCSI HDDs, Mojo. Dell Precision M90, Core2Duo 2.16Ghz, FX1500, SATA 7200rpm Media Composer 3.0 [view my complete system specs]
  • Tue, Apr 29 2008 2:29 PM In reply to
    Re: What is the most commonly used PAL QT codec?
    I'd opt for Sorensen.
    Symphony Nitris 3.0 on 2xquad core XW8400/4(??)GB | MC 3.0 on dual core XW8400/3GB | Mojo SDI | Unity Lanshare 4.23 fibre | MC 3.0 on MacBook 2.16/2.5GB... [view my complete system specs]
  • Tue, Apr 29 2008 2:34 PM In reply to
    • daktulus
    • Posts 376
    • Points 5,035
    thanks. Which QT codec in Sorensen? I guess not too many have Sorensen itsself on the system.
  • Tue, Apr 29 2008 2:47 PM In reply to
    • daktulus
    • Posts 376
    • Points 5,035
    My Sorensen doesn´t have QT at all. Maybe QT or AVI wouldn´t be useful at all. I guess most people have flash?
  • Tue, Apr 29 2008 2:50 PM In reply to
    It seems that when you write "Sorensen" you mean "Squeeze", the application, whereas I was referring to the Sorensen 3 video codec. In my experience a very old codec that nearly all computers can play back, either from a QT container or an AVI container.
    You should be able to use either the Avid, QT-Pro or any encoding program to encode in Sorensen Video 3 codec.
  • Tue, Apr 29 2008 2:57 PM In reply to
    • daktulus
    • Posts 376
    • Points 5,035
    When I open Filter in Avids QT export I dont find Sorensen, I guess I dont have it on the system. Flash doesn´t seem an option either: for mp3 a Sorensen plug-in must be purchased. I guess I´ll take mp-4 and encode in Sorensen Squeeze
  • Tue, Apr 29 2008 3:03 PM In reply to
    daktulus:
    The codec would not be located in "Filters", but under "Settings".
  • Tue, Apr 29 2008 3:40 PM In reply to
    • daktulus
    • Posts 376
    • Points 5,035
    of course: settings, but no such codec. In Sorensen there is a special ppt wmv codec, but the quality is pretty low. I try to figure out how to alter a Squeeze setting. Still, I also need a commonly used high-quality codec...
  • Tue, Apr 29 2008 10:42 PM In reply to
    • DIESELE
    • Joined on Mon, Apr 28 2008
    • Posts 110
    • Points 1,290
    Talk about the blind leading the blind here - and I'm pretty blind too as I have NEVER got a lovely H264 MPG4 export to play.  However most of the above is probably misleading.
    Sprenson i s a compression suite that is shipped with Xpress Pro and seems to partially integrate with Avid.  I have used it to burn DVD's but the fumbling, guesswork and hit and miss factor is typicall of the lack of support, dearth of instruction and lack of vision those that flog the base software have...
    IDespite buying QT,  have ended up using WMV for my 'preview' exports, and this works well with reliable 16:9 frame sizes and small file sizes (although very jaggedy' for most stuff).  Go Windows!!!!
    I suspect, like most I have spent days of trial an error on this.  Grrrrrrr!!!!!!!!!!
    D
    MC 3, XP SP2, Asus P5K-E Mobo, Dual Quad Core 2.4Ghz CPU (3.0 Ghz if I'm up against it!), 4Gb 800Mhz RAM Dual channel, 4 x 500Gb SATA Stripe O pairs, Quadro FX 1500 GFX, Soundblaster Audigy, Mojo SDi.  Sony PVM CRT.  Approved Avid HP 8240 Notebook. Original DIY PC: Shuttle SN85, AMD 3200, 1Gig Ram, Quadro 980, on board sound, on board firewire, 2 x SATA + WD ext HDD - could that be less 'compatible? Never hiccuped once! :-)
  • Wed, Apr 30 2008 5:06 PM In reply to
    • Paddywack
    • Winchester, England.
    • Posts 49
    • Points 515
    I agree with the above Smile
    I use wmv for previews off an FTP site and it gives a good balance between quality and bandwidth as well as being playable on most exec's laptops.
    wmv or Windows Media Video for PC's, preferably wmv9 if you have it - if not you can download it from Microsoft.
    This will play on any PC with a recent version of Windows Media Player and should certainly play in Powerpoint. You can play about with the quality vs playability settings to get the desired effect.
    On a Mac Quicktime is best and Sorenson3 is a codec within Quicktime which you set in the settings option. You can also save quicktime files as DV codec or Avid 2:1 codec or whatever comes on your list, but Sorenson should play in most Quicktime players.
    If you want compatability between both Mac and PC then probably stick to a Quicktime .mov file which should play in Windows Media Player on a PC or you can download the PC version of Quicktime player.
    If you are looking for a good encoder then there is Sorenson Squeeze which may have come with your Avid or TMPGEnc 4.0 XPRESS  is what I use. Very quick, very intuitive and not too expensive. http://tmpgenc.pegasys-inc.com/en/product/index.html
    or Softpepper Video Converter is also pretty good and a bit cheaper: http://softpepper.com/products.html
    Either way you need to export your sequences as a QT Reference file and then drop them into the encoder.
    Good luck
    Need to upgrade! Media Composer Adrenaline running on PC HP XW8000 with 2Gb memory, NVidia 1100, 500Gb SATA Raid, 3Tb GRaid Firewire800 plus lots of Firewire... [view my complete system specs]
    Paddywack Productions Ltd. Freelance editing in the UK
  • Wed, Apr 30 2008 5:31 PM In reply to
    • camoscato
    • Posts 4,686
    • Points 55,850
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    DIESELE:
    Sorensen is also a video codec, as Job pointed out above.
    DIESELE:
    There are some good workflows on this post, if you scroll down to How to DVD.
    good luck,
    Carl
  • Wed, Apr 30 2008 6:03 PM In reply to
    • DIESELE
    • Posts 110
    • Points 1,290
    Hi Carl - thanks for the link and sorry for ranting a bit :)
    I had a bad day yesterday (including picking up a virus that has permanently corrupted my right click menus on drives - and NO I am NOT re-installing Windows to fix it!!!!),  I have just exported a nice MP4 H264 from Avid for the first time - although it is a bit bigger than an WMV.
    The links you gave me are uiseful - wish I'd found here before, but then I'm too busy editing or fixing things to get them to edit!!!
    Cheers
    D
  • Wed, Apr 30 2008 6:04 PM In reply to
    • camoscato
    • Posts 4,686
    • Points 55,850
      Moderator: Meridien
    Hi D,
    No problem.  I'm glad you're getting it worked out.
    adios,
    Carl
  • Wed, Apr 30 2008 7:22 PM In reply to
    no such codec
    That's weird. It has been on all my machines (Macs and PCs) for over 10 years.
  • Wed, Apr 30 2008 8:54 PM In reply to
    On second thought, I'd say that MPEG-1 is the most commonly used codec for distributing QT's for approval. It is the most common format when distributing commercials. I also use it for R&A on scenes, teasers, trailers, etc.
    TMPEGEnc is a great encoder for that, but many ways lead to MPEG-1. MPEG-1 will only give you decent quality at smaller picture sizes, though.
