Latest post Fri, May 2 2008 5:31 AM by thepaintballdude. 3 replies.
  • Tue, Apr 29 2008 12:02 PM
    • JVR
    • Joined on Thu, Jul 13 2006
    • Bulli , Australia
    • Posts 1,232
    • Points 13,760
    DVCproHD
    Hi all just wondering if somebody can point me in the right direction for a DVCproHD P2 files edit to Sd DvD workflow...Oh 1080/50i
    I have Procoder & Sorenson Squeeze
    thanks
    MC 3.0 QTime 7.4.5 win xp pro service pak 3 Core 2 Duo Quad core 2.4 4 gig ram 667mhz pci x nvidia 512mb geforce 7600 162.50 driver 1 x 7200rpm... [view my complete system specs]
  • Wed, Apr 30 2008 11:52 AM In reply to
    • Tugger
    • Champaign Illinois USA
    • Posts 392
    • Points 4,875
    Re: DVCproHD
     I go this route all the itme. Work in an HD project (1080/59.94-I'm in NTSC land) when the project's locked I export a QT ref (project dimensions, same as codec) load into Sorenson (Squeeze 4.5) pop on a mpeg2 preset: compression flavor of your choice (if less than an hour I max it with 2 pas vbr, 8500kbs pcm audio) frame size is the standard (for NTSC) 720X480 If the client wants a 16X9 DVD I check "unconstained" (to create the anamorphic SD image) If the client wants 4X3 I apply a filter preset that crops off 240 pixels from each side, and check "maintain". Third option is to check "lettterbox/pillor" and you'll get a letterboxed 4X3. Hit the squeeze button, and go get a beer, transcoding from HD to SD (especially with a crop) can take a while in Sorenson.
    good luck
    MediaComposer 3 on HP nw9440 (2.17ghz dual proc-nVidia 1500m-4gig RAM) / AXP 5.8 on HP 8710 (2.1ghz dual proc-nVidia n320m quadro-4gig RAM) USB or eSATA... [view my complete system specs]
  • Wed, Apr 30 2008 1:32 PM In reply to
    • JVR
    • Bulli , Australia
    • Posts 1,232
    • Points 13,760
    Re: DVCproHD
    Thanks Tugger,
    I like the beer part!Yes
  • Fri, May 2 2008 5:31 AM In reply to
    Re: DVCproHD
    I just did a project in DVCProHD 720p, and I would just export a full-quality reference file (Avid DV100 Codec). In Avid DVD, I'd simply add it as a normal video. On "Burn" it would transcode it down to SD for the DVD before it burned. It worked great, and looked amazing. Obviously, by going directly to DVD from the reference file doesn't give nearly as much control, but it was the fastest and easiest workflow for me.
    -Matt
    Avid Xpress Pro Academic 5.7.7, Avid Studio Toolkit 5.7, Protools 7.4 with DV Toolkit 2, Dell Precision 380, Pentium D 3.0GHz processor, 4GB RAM, nVidia... [view my complete system specs]
