Latest post Tue, Apr 29 2008 6:46 PM by Dave G. 6 replies.
Page 1 of 1 (7 items)
  • Mon, Apr 28 2008 10:44 PM
    • lmerino
    • Joined on Mon, Dec 19 2005
    • Chicago
    • Posts 215
    • Points 2,935
    Large RAID array, large file count...
    I'm moving towards setting up a 2TB RAID.  I am hearing that there may be trouble with large file counts in the OMFI databases (and unknown if there is a problem with MXF databases).
    Does anyone have experience with this size, single raid?  I know I need the storage, and I'm not sure of a better way to do it.
    Dell Precision M90 4GB RAM Xpress Studio 5.8 [view my complete system specs]
  • Mon, Apr 28 2008 11:30 PM In reply to
    • rinzeschuurman
    • Amsterdam, The Netherlands
    • Posts 116
    • Points 1,350
    Re: Large RAID array, large file count...
    Well running a 6 tb raid5 setup in 2x2 tb and 1x1 tb partitions (1 tb for redundancy)... windows had problems with building partitions over 2 tb. No problems with the filecount, BUT i do capture all at max resolution so i think i run out of disk space before i run out of the number of files windows/avid is able to deal with. Also i use mxf, which is better equiped to deal with a lot of files. Beside that, i rename the MXF/OMFI folder to the project name if i continue to work on a different project.
    Self build soundproofed computercase which also functions and a supporting part of the selfbuild desk/ computer -Quad intel on asus striker extreme board... [view my complete system specs]
    "Software bugs are impossible to detect by anybody except the end user"
  • Mon, Apr 28 2008 11:32 PM In reply to
    • lmerino
    • Chicago
    • Posts 215
    • Points 2,935
    rinzeschuurman:
    What do you mean by this?  Is this the virtual drive idea that I am reading about on the forums?  Can I rename the MXF folder and still access it?
  • Mon, Apr 28 2008 11:57 PM In reply to
    No, once you rename that folder it becomes invisible to Avid. Do a search on Virtual drives - I think they are a great way to manage media on large arrays.
    MC 2.8.1 Dell 670, Dual Xeon 3.6 GHz, Win XP SP2, 3GB RAM (6x512) QT 7.2, nVidia Quadro FX3500/256MB, 8x500GB RAID 5 controlled by 3Ware 9650SE-8LPML in... [view my complete system specs]
  • Tue, Apr 29 2008 12:07 AM In reply to
    • rinzeschuurman
    • Posts 116
    • Points 1,350
     I change the names so it that project becomes invisible for avid, and i dont run into trouble with mediafiles of several different projects in one OMFI/MXF folder. The folder is of course still accessable in windows of course. I dont know about virtual drives... I do know about shared folders that can be mapped as a drive, so you can use the harddisks two or three avids connected by Gb lan as kind of a poor man's unity/lanshare
  • Tue, Apr 29 2008 12:26 AM In reply to
    http://community.avid.com/forums/p/57042/318523.aspx#318523
  • Tue, Apr 29 2008 6:46 PM In reply to
    • Dave G
    • Vancouver, Canada
    • Posts 120
    • Points 1,675
    Just to clarify, when using the MXF format/file structure, there is no problem - Avid automatically creates a new directory when the number of files exceeds 5,000 files or so.
    If you look inside the Avid MediaFiles / MXF directory, you'll see a folder called "1".  When the number of files exceeds 5,000, it will create directory "2", and so on.  All sub-folders within the "MXF" directory will appear online within Avid.
    Dave
    Lots :) 3 Xpress Studio Suites, 40 Xpress Pro Seats, Avid support for two Vancouver production companies. [view my complete system specs]
    Avid Editing Sensei
