I'm moving towards setting up a 2TB RAID. I am hearing that there may be trouble with large file counts in the OMFI databases (and unknown if there is a problem with MXF databases).
Does anyone have experience with this size, single raid? I know I need the storage, and I'm not sure of a better way to do it.
Well running a 6 tb raid5 setup in 2x2 tb and 1x1 tb partitions (1 tb for redundancy)... windows had problems with building partitions over 2 tb. No problems with the filecount, BUT i do capture all at max resolution so i think i run out of disk space before i run out of the number of files windows/avid is able to deal with. Also i use mxf, which is better equiped to deal with a lot of files. Beside that, i rename the MXF/OMFI folder to the project name if i continue to work on a different project.
rinzeschuurman:Beside that, i rename the MXF/OMFI folder to the project name if i continue to work on a different project.
What do you mean by this? Is this the virtual drive idea that I am reading about on the forums? Can I rename the MXF folder and still access it?
No, once you rename that folder it becomes invisible to Avid. Do a search on Virtual drives - I think they are a great way to manage media on large arrays.
I change the names so it that project becomes invisible for avid, and i dont run into trouble with mediafiles of several different projects in one OMFI/MXF folder. The folder is of course still accessable in windows of course. I dont know about virtual drives... I do know about shared folders that can be mapped as a drive, so you can use the harddisks two or three avids connected by Gb lan as kind of a poor man's unity/lanshare
http://community.avid.com/forums/p/57042/318523.aspx#318523
Just to clarify, when using the MXF format/file structure, there is no problem - Avid automatically creates a new directory when the number of files exceeds 5,000 files or so.
If you look inside the Avid MediaFiles / MXF directory, you'll see a folder called "1". When the number of files exceeds 5,000, it will create directory "2", and so on. All sub-folders within the "MXF" directory will appear online within Avid.
Dave
Avid Editing Sensei
