Latest post Mon, Apr 28 2008 5:16 PM by ragingjo. 2 replies.
  • Mon, Apr 28 2008 6:47 AM
    • ragingjo
    • Posts 4
    • Points 60
    re-installation of Avid dv
    I hope there's someone out there who can help me with this problem. I have an old avid 3.0 version.
    My internal hardrive crashed so i had to replace it. My os was win 2k so I re-installed all the softwares and drivers again.  I even re-installed avid v.2.0 to install fixes before re-installing v 3.0.  re-installed service pack 2 on win 2k before re-installing avid xpress dv 3.0. Finally, when I tried to start avid, I got this message:
    File 'c:\Program Files\Avid\Avid Xpress DV\Avid Users\ MyName\MyName\.ave" not found
    Exception:SYS_ERROR, Status 3, msg: The system cannot find the path specified.
    Avid was unable to start.
    Thank you.
    Luis
  • Mon, Apr 28 2008 10:21 AM In reply to
    Re: re-installation of Avid dv
    Are you opening a new project, with new User Settings, or ones archived from your system prior to the crash?  Sounds like the User Settings are not in the same place that they sed to be.  The .ave file is part of the User Settings data.
  • Mon, Apr 28 2008 5:16 PM In reply to
    • ragingjo
    • Posts 4
    • Points 60
     Hello,
    Thank you for your quick response.  The "Select Project" dialogue doesn't appear.  This message appears:
    You may be right about files not being in the right place.  What should I do to make avid find the specified file.
    Thank you.
