Latest post Tue, Apr 29 2008 10:35 PM by creativethinker. 6 replies.
Page 1 of 1 (7 items)
  • Mon, Apr 28 2008 5:09 AM
    Need a little help...
    I finished a 720P 23.97 project in Avid that was shot using the HVX P2 Cards.
    The final product needs to be delivered on mini DV. How do I get the timeline to put out to my DV device? ( which is the XL2)
    Since its an HD projec it puts out DVCPRO which my DV device can not read. How do I get sequence onto a SD timeline so I out put to my DV device.
    I have tried the transcoder feature which I selected to convert to Avid 1x1 and maybe I didnt do it right but wasnt able to get a signul out.
    any thoughts?
    Intel Xeon E5345 Quad 2.33GHz - TyanS2696 MotherBoard - 4Gb Quad Channel DDR2 667 Ram - Nvidia Quadro FX 540 - 160GB (boot drive) 1.2 TB Raid 0 (4x320... [view my complete system specs]
  • Mon, Apr 28 2008 6:52 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 3,491
    • Points 40,375
    Re: Need a little help...
    Do a mixdown to DV25 and output that.  It should solve your problem.
  • Mon, Apr 28 2008 8:39 AM In reply to
    How ?
  • Mon, Apr 28 2008 12:41 PM In reply to
    i suppose you have to go to the format tab and select 25i instead of 720p. then your
    camcorder should understand the signal. i would assume you will have to switsch the format in that
    tab before you try to make a videomixdown, to get the right codecs provided.
  • Mon, Apr 28 2008 5:48 PM In reply to
    Thats what I was trying to do, but there was only one selection which was the format Im working in now.
    I really need this done today haha, any other way?
  • Tue, Apr 29 2008 12:30 AM In reply to
    • jwrl
    • Posts 3,491
    • Points 40,375
    Sorry for the late response - I'm in the middle of finishing not one but two projects.
    I don't deal with 720p, so this is speculative.  Export a QT ref version of your cut, create a new DV project and import the QT into that.  Play that out to your deck.
    It'll be slow, but I can't immediately see why it wouldn't work.
  • Tue, Apr 29 2008 10:35 PM In reply to
    I ended up trying that out too, funny thing is when I made a Quick time reff files, and I load the file to make sure its there... no fotage comes up.. weird. So i exported a uncompresed quick time and brought into a SD project and got it to out put to a DV deck. thank you all for your help!
