Latest post Fri, May 2 2008 12:33 AM by Firefrog. 16 replies.
  • Sat, Apr 26 2008 9:25 PM
    • sjon
    • netherlands
    • Posts 210
    • Points 2,780
    new to mc/windows
    I temporarely switched from Xpress pro/mac to the latest version of MC/Windows and have a few questions (I work on macbookpro -newest version/dual boot windows xp):
    1. where is the green/blue switch dot in the timeline to switch to client monitor (or how should i do that in Windows)?
    2. where on the c/drive are the media-files located (I cannot find an omfi-file)?
    3. what is the difference between 1080i/50 and 1080i/50hdv (or: which should I choose - when starting a new project - using my sony hvr/z1e filming 1080)?
    4. Avid is very -too- bright on my (mac)-screen. How can I make it less bright?
    Thanks for helping me out....
    mac 0SX 10.5.2. dual boot 2.6 ghz intel core 2 duo 4 gb 667 mhz ddr2 sdram media composer 2.8 [view my complete system specs]
  • Sat, Apr 26 2008 10:03 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,861
    • Points 175,665
    Re: new to mc/windows
    sjon:
    Make sure you have calibrated your monitor under the display system prefs(in bootcamp it's START>CONTROL PANELS>DISPLAY...I think...)first and then use the brightness adjustment on the keyboard.
    sjon:
    The HDV project is for thin raster HDV media. If you aren't shooting in that format, just use the former.
    sjon:
    Are you saving media to your internal? There isn't a "C" drive on a Mac but one will be simulated in bootcamp. Your Media folders, if you are saving media there are on the root level of the drive.
    sjon:
    There isn't one in MC.
  • Sat, Apr 26 2008 10:17 PM In reply to
    • sjon
    • netherlands
    • Posts 210
    • Points 2,780
    thanks blkdg.
    If there isn't a blue/green dot in MC, how can I switch/arrange output to the camera (and then to the client monitor). I hope it can be done in MC...!
  • Sat, Apr 26 2008 10:30 PM In reply to
    • sjon
    • netherlands
    • Posts 210
    • Points 2,780
    ps loaded xpress pro in windows and there's also no blue/green switch....that's odd. Windows can firewire out to camera, I hope....
  • Sat, Apr 26 2008 11:56 PM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 3,491
    • Points 40,375
    Xpress hasn't had the blue-green switch for quite some time now.
  • Sun, Apr 27 2008 12:21 AM In reply to
    • sjon
    • netherlands
    • Posts 210
    • Points 2,780
    ...but still makes me wonder if I can (and how) to output from Avid > firewire > camera > client monitor. I used to do that all the time with the older xpress pro...
  • Sun, Apr 27 2008 1:03 AM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,861
    • Points 175,665
    Sure you can. It's on all the time now.
  • Sun, Apr 27 2008 3:34 AM In reply to
    • sjon
    • netherlands
    • Posts 210
    • Points 2,780
    so if it's not working, I should check my camera etc....Iow: there are no ways to configure this in MC. It works automatically (?)
  • Sun, Apr 27 2008 3:49 AM In reply to
    Confidence View?
    MacPro dual 2.66GHz 2GB RAM NVIDIA GeForce 7300 GT Storage: 2TB G-Speed eS with controller card 3x500GB Hitachi SATA-II internals various external... [view my complete system specs]
  • Sun, Apr 27 2008 6:30 AM In reply to
    • Firefrog
    • Australia
    • Posts 121
    • Points 1,625
    Timeline hamburger menu - output over firewire. Or something like that.....Not infront of Avid right now. That caught me too after the upgrade to MC.
    I was changing firewire cables and cycling camera power etc etc, till I sent the timeline out over firewire via the timeline hamburger menu.
    Dell Precision 490 Workstation, MC 2.8.1, QT 7.3, NVidia 91.85 Quadro FX 550, 3gig Ram, No Avid Hardware - Yet Two internal SATA drives. Various external... [view my complete system specs]
    http://www.fluidvision.com.au
  • Sun, Apr 27 2008 9:08 AM In reply to
    • sjon
    • netherlands
    • Posts 210
    • Points 2,780
    I am confused. When I connect the sony z1e to my old xpress/dv/mac system I get output to the camera through firewire. Connected to the new system (MC/Windows): no output to the cam. Also I cannot find 'timeline out over firewire' in the hamburger menu. Also I wonder (and is maybe connected to the problem): if I set a new project up I can (amongst others) choose between the 1080i/50 en 1080i/50 hdv. (Blkdg answered this question a bit)...but when I choose 1080i/50 there's no video-signal in capture (i.e. I cannot click the red button). Hope you can help me out....
  • Sun, Apr 27 2008 11:28 AM In reply to
    • Firefrog
    • Australia
    • Posts 121
    • Points 1,625
    Sorry - Could have sworn it was in that hamburger menu.
    It is under - Settings, video display, output to DV Device.
  • Sun, Apr 27 2008 11:44 AM In reply to
    • sjon
    • netherlands
    • Posts 210
    • Points 2,780
    I've found that one yesterday, but cannot enable it.... I can enable confidence view....but not dv output setting. what can be the problem???
  • Sun, Apr 27 2008 12:06 PM In reply to
    • sjon
    • netherlands
    • Posts 210
    • Points 2,780
    ps. I found a picture on the net: http://www.geniusdv.com/weblog/archives/avid_express_pro_and_display_settings.php Here dv output is in dark black and can (!) be selected. In my window it's not and cannot be selected. In Special > Device > IEEE 1394 is selected (there's only this option there)...
  • Sun, Apr 27 2008 12:10 PM In reply to
    • sjon
    • netherlands
    • Posts 210
    • Points 2,780
    sorry should be: http://www.geniusdv.com/weblog/archives/avid_express_pro_and_display_settings.php
