I temporarely switched from Xpress pro/mac to the latest version of MC/Windows and have a few questions (I work on macbookpro -newest version/dual boot windows xp):
1. where is the green/blue switch dot in the timeline to switch to client monitor (or how should i do that in Windows)?
2. where on the c/drive are the media-files located (I cannot find an omfi-file)?
3. what is the difference between 1080i/50 and 1080i/50hdv (or: which should I choose - when starting a new project - using my sony hvr/z1e filming 1080)?
4. Avid is very -too- bright on my (mac)-screen. How can I make it less bright?
Thanks for helping me out....
sjon:4. Avid is very -too- bright on my (mac)-screen. How can I make it less bright?
Make sure you have calibrated your monitor under the display system prefs(in bootcamp it's START>CONTROL PANELS>DISPLAY...I think...)first and then use the brightness adjustment on the keyboard.
sjon:3. what is the difference between 1080i/50 and 1080i/50hdv (or: which should I choose - when starting a new project - using my sony hvr/z1e filming 1080)?
The HDV project is for thin raster HDV media. If you aren't shooting in that format, just use the former.
sjon:2. where on the c/drive are the media-files located (I cannot find an omfi-file)?Are you saving media to your internal? There isn't a "C" drive on a Mac but one will be simulated in bootcamp. Your Media folders, if you are saving media there are on the root level of the drive.
sjon:1. where is the green/blue switch dot in the timeline to switch to client monitor (or how should i do that in Windows)?
There isn't one in MC.
thanks blkdg.
If there isn't a blue/green dot in MC, how can I switch/arrange output to the camera (and then to the client monitor). I hope it can be done in MC...!
Xpress hasn't had the blue-green switch for quite some time now.
...but still makes me wonder if I can (and how) to output from Avid > firewire > camera > client monitor. I used to do that all the time with the older xpress pro...
Sure you can. It's on all the time now.
so if it's not working, I should check my camera etc....Iow: there are no ways to configure this in MC. It works automatically (?)
Confidence View?
Timeline hamburger menu - output over firewire. Or something like that.....Not infront of Avid right now. That caught me too after the upgrade to MC.
I was changing firewire cables and cycling camera power etc etc, till I sent the timeline out over firewire via the timeline hamburger menu.
Sorry - Could have sworn it was in that hamburger menu.
It is under - Settings, video display, output to DV Device.
