Latest post Mon, Apr 28 2008 6:00 AM by hidefcowboy. 2 replies.
  • Sat, Apr 26 2008 8:48 AM
    Please help with my new project
    What project setting should I use if half my footage is dv ntsc 30i and the other half is dv 24p. Should I use the 23.976p project setting or 30i.
    Oh, and I will later be later converting to the Pal format for broadcast. If that changes anything.
  • Sat, Apr 26 2008 5:03 PM In reply to
    • Codec Moment
    • Joined on Mon, May 21 2007
    • Philadelphia
    • Posts 180
    • Points 2,420
    Re: Please help with my new project
    I'd say 30. The 24frame footage is still 30fps, it's just 24 frames imbedded in 30fps video. Assuming you'll be going to NTSC (you said you'll convert to PAL, but I'm guessing you're still finishing in NTSC as well), everything will end up 30fps either way, and pulling out arbitrary frames from your 30frame video and then re-adding them when you finish will look pretty bad. The 24-frame material is already pulled down in a way that people are used to.
    So the short answer is unless you're only releasing in PAL (and want to work at 24 which will be sped up to 25 for release), go with 30.
    Mac OSX 10.4.11 Avid Media Composer v2.8 (software only) JVC BR-HD50 MacPro Dual Core Intel Xeon 2.66Ghz 8GB RAM [view my complete system specs]
    I trust orange juice more than I trust most people.
  • Mon, Apr 28 2008 6:00 AM In reply to
    I agree.. if it's TV, go 29.97. When folks ask, tell them you are working in "480i" so they will think it's all hip. ;)
    Don't trust the internet...
