So i just got my academic version of Avid Media Composer. But after I install it every time i try to start it up i get this message that reads: "Segmentation fault" in thread "MainThread", at address 0X0... and then I get a MAC OSX system message that tells me that the Application has unexpectedly quit.. Why is this? Im running Tiger 10.4.11 and Avid Media Composer 2.8
any help would be appreciated! thank you!
What are your CPU specs? What version of QT and what else do you have attached to the system?
Did yo install the software in a user with Admin privileges?
well these are specs..
Model Name: MacBook
Model Identifier: MacBook1,1
Processor Name: Intel Core Duo
Processor Speed: 2 GHz
Number Of Processors: 1
Total Number Of Cores: 2
L2 Cache (per processor): 2 MB
Memory: 2 GB
Bus Speed: 667 MHz
Boot ROM Version: MB11.0061.B03
SMC Version: 1.4f12
and i dont know what QT means. I did install it under the administrator account.I am the only user of this computer
Ok, that's a Macbook. The Avid software is not qualified to run on it.
However, if you hold down the G+O keys when launching, it may start up.
Wow, thank you! it works! by holding down those 2 keys... So am i going to have problems because of it? Can I use this dongle when i get iMac?
THANK YOu!!!!
Absolutely. You can even use it on a PC if you are inclined to.
The only thing you are going to lack using this method is any 3D effects as you have turned them off with that launch modifier.
