Latest post Fri, Apr 25 2008 7:07 PM by BLKDOG. 5 replies.
Page 1 of 1 (6 items)
  • Fri, Apr 25 2008 7:11 AM
    • AuxHernandez
    • Joined on Fri, Apr 25 2008
    • Los Angeles
    • Posts 3
    • Points 45
    Segmentation Fault error?
    So i just got my academic version of Avid Media Composer. But after I install it every time i try to start it up i get this message that reads: "Segmentation fault" in thread "MainThread", at address 0X0... and then I get a MAC OSX system message that tells me that the Application has unexpectedly quit.. Why is this? Im running Tiger 10.4.11 and Avid Media Composer 2.8
    any help would be appreciated! thank you!
    Mac Book Intel core duo 2.0 Ghz Ram 250 GB Seagate drive [view my complete system specs]
    Filed under: , ,
  • Fri, Apr 25 2008 12:52 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 12,710
    • Points 161,440
      Moderator: MCA Mac
    Re: Segmentation Fault error?
    What are your CPU specs? What version of QT and what else do you have attached to the system?
    Did yo install the software in a user with Admin privileges?
  • Fri, Apr 25 2008 4:52 PM In reply to
    • AuxHernandez
    • Los Angeles
    • Posts 3
    • Points 45
    well these are specs..
      Model Name: MacBook
      Model Identifier: MacBook1,1
      Processor Name: Intel Core Duo
      Processor Speed: 2 GHz
      Number Of Processors: 1
      Total Number Of Cores: 2
      L2 Cache (per processor): 2 MB
      Memory: 2 GB
      Bus Speed: 667 MHz
      Boot ROM Version: MB11.0061.B03
      SMC Version: 1.4f12
    and i dont know what QT means. I did install it under the administrator account.I am the only user of this computer
  • Fri, Apr 25 2008 4:58 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 12,710
    • Points 161,440
      Moderator: MCA Mac
    Ok, that's a Macbook. The Avid software is not qualified to run on it.
    However, if you hold down the G+O keys when launching, it may start up.
  • Fri, Apr 25 2008 6:15 PM In reply to
    • AuxHernandez
    • Los Angeles
    • Posts 3
    • Points 45
    Wow, thank you! it works! by holding down those 2 keys... So am i going to have problems because of it? Can I use this dongle when i get iMac?
    THANK YOu!!!!
  • Fri, Apr 25 2008 7:07 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 12,710
    • Points 161,440
      Moderator: MCA Mac
    Absolutely. You can even use it on a PC if you are inclined to.
    The only thing you are going to lack using this method is any 3D effects as you have turned them off with that launch modifier.
