Latest post Fri, May 16 2008 2:20 AM by ez3401. 5 replies.
Page 1 of 1 (6 items)
  • Fri, Apr 25 2008 12:45 AM
    • Sam Cave
    • Joined on Wed, Apr 23 2008
    • Posts 1
    • Points 25
    external hard drive/firewire problem
    So...
    I am running Xpress Pro, and trying to work with my DV camera and external LaCie drive attached at the same time. My MacBook Pro has both normal firewire (DV) and rectangular firewire 400 (for the external) ports. For some reason, both ports will not function at the same time. I have to import the footage onto my computer's hard drive, then disconnect the camera and connect the hard drive...you get the idea. Any help would be awesome!
    Also - what is the best way to move/delete MXF Avid media files?
  • Fri, Apr 25 2008 1:40 AM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 2,682
    • Points 30,755
    Re: external hard drive/firewire problem
    The rectangular firewire port is the for Firewire 800.  The one shaped like a arrowhead is for FW400.  Not clear how things are connected but sending the DV signal from the deck or camera thru a LaCie drive has been less than reliable.  You should be able to plug the drive into one port and the deck into the other as long as you don't have a Mojo.  (You might need a FW800 to FW400 cable to make the connections if the LaCie is FW400.)   If that doesn't seem to help, see if you can get a different firewire drive for a test to see if the problem goes away if you don't use the LaCie.
    Best way to delete MXF media is using the Media Tool within the Avid.  Best way to move media is to become familiar with the Consolidate command.
    MacPro, MacBook Pro and a Cube. The Cube doesn't do much but it looks cool. [view my complete system specs]
  • Fri, Apr 25 2008 2:04 AM In reply to
    • jasperfdo
    • Joined on Wed, Oct 11 2006
    • Los Angeles
    • Posts 383
    • Points 4,920
     the two ports will probably not functions at the same time because they are using the same bus on the laptop.  get an add in firewire PC card, and that will probably fix your problem.
    Dell Precision 690, Intel 3.2GHz Dual Core Xeon (5060)4GB RAM, nVidia Quadro FX 3500 / Media Composer v3.0 / Mojo [view my complete system specs]
    kyler boudreau | www.theatereleven.com
    "If you tell a lie long enough, it becomes the truth." - Joseph Goebbels
  • Fri, Apr 25 2008 5:57 AM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 2,682
    • Points 30,755
    The two ports will function at the same time but share bandwidth if they're on the same bus.  It wouldn't make much sense for a manufacturer to install two ports and have only one function at a time as the resulting calls to tech support would be overwhelming.  DV and a Firewire disk combined will only consume maybe 25% of the available bandwidth so unless you've got a Mojo on the bus (it doesn't like to share at all) it shouldn't be a problem.
  • Fri, Apr 25 2008 5:00 PM In reply to
    For general use, both ports function at the same time. However, with Pro Tools, MacBook Pro users were required to get a Firewire ExpressCard because it did not like multiple firewire devices on the same bus. I would not be surprised if Avid is the same.
    First I would try a different drive if you have access to one, running one device into the 400 port and one into the 800. Daisy chaining a camera through your drive is unlikely to give good results.
    If that doesn't work, I would move on to getting an ExpressCard adapter. Make sure the card is Mac compatible. Belkin and Siig are usually reliable manufacturers. Avoid cards that have both USB and Firewire. Just get a dedicated Firewire card.
    Let us know how everything works out.
    Mac Pro 2 x 2.8GHz Quad-Core Intel Xeon, ATI Radeon 2600, 2GB RAM, XPress Pro 5.8, Unity v5.1 [view my complete system specs]
  • Fri, May 16 2008 2:20 AM In reply to
    • ez3401
    • Joined on Fri, May 16 2008
    • Posts 1
    • Points 5
    I have the same problem. I have been searching  for a solution for a long time..
    I have a macbook pro.
    Firewire 800
    Firewire 400
    LaCie 1Tb (Big disk extrem+) Which has Firewire 800, 400, USB
    When I have the LaCie hooked up by way of FW 800 my DV camera won't work (hooked up to the FW 400 port)
    It seems I will have to do the same as you and download all by DV footage to the Mac's hardrive, then transfer to the LaCie. BUT what a pain in the butt. I did not expect this from a Mac book "pro".
    I use final cut 4.
