Latest post Sat, Apr 26 2008 6:36 PM by Dreamer D. 8 replies.
Page 1 of 1 (9 items)
  • Thu, Apr 24 2008 4:20 PM
    using resize effect to move images but motion is not smooth...
    I imported pics into my bin then placed then into the timeline, then applied the Resize Effect on each one.  I have done this before with another project and had no issues.  Now the motion is shaky and awkard.  I looked at the earlier project and the images move and resize very smoothly.  I cannot find out why the new project is turning out differently.  Rendering makes no difference.
    Avid Xpress Pro HD 5.2.4 Avid Pro Tools 6.5.3 Dell Windows XP PRO SP2 Pentium D 2.80Ghz 2.00 GB RAM Harddrives C: 80 GB D: 250GB ... [view my complete system specs]
  • Thu, Apr 24 2008 4:47 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,267
    • Points 168,385
      Moderator: MCA Mac
    Re: using resize effect to move images but motion is not smooth...
    Can you please give us a complete rundown off your system hardware (Including storage) and software as well as in what resolution you are working and  what version of QT?
  • Thu, Apr 24 2008 5:31 PM In reply to
    Avid Xpress Pro HD 5.2.1
    Windows XP PRO SP2
    Dell
    Pentium D 2.80Ghz
    2.00 GB RAM
    Harddrives
    C: 80 GB
    D: 250GB
    EXT 500 GB
  • Thu, Apr 24 2008 8:52 PM In reply to
    It seems to have to do when I use the Advanced keyframes under the Effects Editor.  I don't want to have to redo all the of the pics.  Is there a way to get the Advanced key frames to work smoothly?
    It seems intent on making me delete the original effect then put it back on the pic then use the Effects editor without clicking on Advanced keyframes.  This  is very weird.  I did the first project without using Adv keyframes, which is why they move smoothly.
    What to do?
  • Thu, Apr 24 2008 9:05 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,267
    • Points 168,385
      Moderator: MCA Mac
    Try this....
    Copy the Resize effect template  to your bin. Now add a fresh Resize to your segmen and open the position pane. Drop the effect template from your bin directly onto that pane. Now do the same for the size.
    Does that put the  correct values in without having to promote the effect to Adv keyframes?
  • Fri, Apr 25 2008 6:00 AM In reply to
     does anyone know the reason for adv keyframes to act this way?
  • Sat, Apr 26 2008 1:31 PM In reply to
     I couldn't figure out how to copy the resize effect template to my bin, so i just re-did everything.  Everything is fine now and the project is finished but Is there a know issue with Adv keyframes?
  • Sat, Apr 26 2008 3:24 PM In reply to
    • JVR
    • Joined on Thu, Jul 13 2006
    • Bulli , Australia
    • Posts 1,209
    • Points 13,435
    Whats wrong with Pan & Zoom?
    MC 3.0 AXP 5.8.3 QTime 7.3 win xp pro service pak 2 Core 2 Duo Quad core 2.4 clocked to 3.1 4 gig ram 667mhz pci x nvidia 512mb geforce 8600 162... [view my complete system specs]
  • Sat, Apr 26 2008 6:36 PM In reply to
    • Dreamer D
    • Joined on Tue, Sep 18 2007
    • NYC
    • Posts 107
    • Points 1,495
    hamstertamer:
    When you have the Effects Editing box open, there's a little effect icon at top.  After you apply your effect the first time, with all the settings the way you want, click on that icon and drag it to your bin.  Then, going forward, anytime you want to use the same effect elsewhere in your timeline, you drag it from your bin to that place and all the same settings apply.
    Avid Xpress Pro v5.8......Dell Precision Workstation 390......Intel Core 2 Duo E6420 (2.13GHz/Dual-core)......Windows XP Pro (SP2)......2 GB DDR2 ECC SDRAM... [view my complete system specs]
    I edit in my dreams*
