Latest post Tue, Apr 29 2008 9:09 PM by Guywithcat. 7 replies.
  • Thu, Apr 24 2008 3:48 PM
    • guima_br
    • Joined on Thu, Aug 23 2007
    • Sao Paulo - Brazil
    • Posts 4
    • Points 30
    buying a new cpu
    Hi everyone, I've already read some system specs topics but I'm buying a new "used" computer and I'm in doubt if my choice will run fast with avid xpress pro 4.7.
    I'm particular worried about audio board, since my Toshiba laptop has a Realtek board and can't open Avid without an external USB audio board, and I really don't want to use this method with my new computer.
    Besides, I'll work with Panasonic HVX-200 P2 and Hi-def resolutions to edit short-films, and After Effects 7/CS3 and Photoshop CS3, so I don't want to buy a slow system.
    In my work, I use the computer i wrote in my profile, and it works real fine.
    Can you please give a comment about the computer below?
    Tks in advance,
    Guilherme
    Desktop Emachines T6524
    CPU:
    AMD Athlon™ 64 3500+ Processor (64-bit with AMD64 Technology)
    (2.20GHz, 2000MHz FSB, 512KB L2 cache)
    Operating System:
    Genuine Microsoft® Windows® XP Media Center Edition 2005
    Chipset:
    ATI RS482
    Memory:
    1024MB DDR (2 × 512MB), 400MHz Dual Channel
    Expandable to 4GB
    Hard Drive:
    200GB (7200rpm, 2MB cache)
    Optical Drives:
    16x DVD±RW multiformat double layer drive
    48x CD-ROM drive
    Media Reader:
    8-in-1 digital media manager (Secure Digital™ (SD), Smart Media, Micro Drive, Memory Stick®, Memory Stick Pro®, Compact Flash, Mulitimedia Card, USB 2.0)
    Video:
    ATI Radeon® Xpress 200 (PCI-Express® )
    Up to 128MB DDR shared video memory
    PCI-Express
    ® (PCI-E x16) slot available for upgrade
    Sound:
    AC '97 Audio, Dolby 5.1 (6-channel)
    Network:
    10/100Mbps integrated Ethernet LAN
    Modem:
    56K ITU V.92-ready Fax/Modem
    Peripherals:
    Premium Multimedia Keyboard, 2-Button Wheel Mouse, Amplified Stereo Speakers
    Ports/Other:
    7 USB 2.0 (2 in front, 4 in back, 1 in Media Reader), 2 IEEE 1394 (1 in front, 1 in back), 1 VGA external connector, 1 parallel, 2 PS/2, 5 audio ports (2 in front, 3 in back)
    Dimensions:
    14.25"H x 7.25"W x 16"D
    Weight:
    23 lbs (PC only, no packaging)
    Monitor Flat Emachines E17T4
    Viewable Area:
    17" viewable (diagonal)
    Widescreen 16:9 Aspect Ratio
    Panel Type:
    LCD active matrix TFT WXGA
    Resolution:
    1280 × 720 (native and maximum)
    Dot Pitch:
    0.291mm
    Brightness:
    250 cd/m²
    Contrast Ratio:
    500:1
    Response Time:
    8ms
    Screen Treatment:
    Antiglare
    Colors:
    16.2 million
    User Controls:
    Power on/off button, on screen display menu control buttons
    Viewing Angles:
    140° left/right, 130° up/down
    Signal Inputs:
    Analog (VGA)
    Ports:
    AC power input, Kensington security lock slot
    Agency Certifications:
    Energy Star® , UL, cUL, FCC Class B, NOM, CE, VCCI, CB, RoHS
    Display Stand:
    Included (adjustable tilt)
    Mount:
    Compatible with VESA (4 × 100mm) compliant mounting solutions
    Electrical Requirements:
    20 watts (normal operation)/1 watt (power-save)
    100-240 VAC, 50/60Hz
    Dimensions:
    16.1"W x 13.9"H x 6.5"D with stand
    16.1"W x 10.7"H x 2.3"D without stand
    Weight:
    6.9 lbs. with stand
    6.2 lbs. without stand
    Warranty:
    1 year parts and labor
  • Thu, Apr 24 2008 3:54 PM In reply to
    Re: buying a new cpu
    AMD is not supported
    Media Center Edition is not supported
    ATI Radeon is not supported
    ... I'd probably go for more RAM.
    ... just a thought, why not pick one of the "qualified" system, and get a used one of those ... or check out HP's Refurb Outlet ...
    Media Composer 3.0 w/Mojo (analog), HP xw8400, 1xQC 3.0GHz, 4GB RAM, FX 3700, 500GB Boot, 1x1TB & 1x500GB internal SATA media drives (temp), 2xHP L2245w... [view my complete system specs]
  • Thu, Apr 24 2008 7:19 PM In reply to
    • mattman
    • Fort Myers, Florida
    • Posts 97
    • Points 1,245
     Unless I am overlooking it, I only see one hard drive.  You will want to keep your media on a separate drive or raid array depending on what speed you will need.
    Xpress Pro 5.6.4 - Mojo, Tyan S2676 Motherboard, dual Xeon 3.2, 4 gig ddr2 ram, 4 300 gig Sata drives, raid 5, 3ware 9550SX Sata II controller, 500... [view my complete system specs]
    Mattman Life is good, eternal life is better.
  • Thu, Apr 24 2008 7:59 PM In reply to
    • raspago
    • FL, USA
    • Posts 735
    • Points 9,120
    ,- In other words:
    It's a NO -NO
    Custom made Intel core 2 duo 2.4 (overclocked to 3.0) Nvidia 8800GS, 3GB Ecc Ram, E-MU 1212M Sound card, Sata Drives, Analog Mojo. [view my complete system specs]
  • Sat, Apr 26 2008 5:49 PM In reply to
    • guima_br
    • Posts 4
    • Points 30
    ok then, it's a big NO for it. tks!
  • Sat, Apr 26 2008 5:51 PM In reply to
    • guima_br
    • Posts 4
    • Points 30
    sorry randal, but i live in brazil and never heard about an hp refurb outlet in here. i don't think they have one here.
    and qualified systems are too expensive in brazil, so we usually mount our own system with separate parts. also, i'll look for some used systems.
  • Mon, Apr 28 2008 11:10 PM In reply to
    • DIESELE
    • Joined on Mon, Apr 28 2008
    • Posts 104
    • Points 1,250
    Due to the demise of my approved and Avid work only dedicated HP Notebook (that has been an absolute PITA since I bought it from my frioendly re-seller - bad pool errors, corrupt databases killing projects, BSOD's and then culminating in a thermal 'dusty CPU' fault) I have just had to pop a Quadro 980 GFX card in my Shuttle AMD 3200 home built 'internet; PC to 'carry on'.  Never has Avid run better - and that on a mish mash of 1.3Gb allsorts of RAM!
    Really not sure on this approved stuff and £400 GFX cards therefore!!!
    To replace this great 'lifesaving'  4 yr old Shuttle, I'm now looking at
    Shuttle SP35P2 Pro - SKT775 for Intel Single/Dual/Quad Core - 2x E-SATA (£300)
    Intel Core 2 Quad Q6600 G0 Stepping (2.4GHz 1066MHz) Socket 775 L2 8MB Cache (£150)
    Anyone any system experience comments for this newbie maverick?
    D
    MC 3, XP SP2, Asus P5K-E Mobo, Quad Core 2.7Ghz CPU (3.0 Ghz if I'm up against it!), 4Gb 800Mhz RAM Dual channel, 4 x 500Gb SATA Stripe O pairs, Quadro FX 1500 GFX, Soundblaster Audigy.  Approved Avid HP 8240 Notebook. Original DIY PC: Shuttle SN85, AMD 3200, 1Gig Ram, Quadro 980, on board sound, on board firewire, 2 x SATA + WD ext HDD - could that be less 'compatible? Never hiccuped once! :-)
  • Tue, Apr 29 2008 9:09 PM In reply to
    DELL refurb will ship to brazil.
    HP XW8400 Dual, Dual Core; 4 TB Dulce RAID 5; 3GB Ram; XPRO (latest version); AJHD 1400; HP XW8400 Dual, Dual Core; 7 TB G-TECH RAID 5 (2 encl); 3GB... [view my complete system specs]
    Eating is a moral act. If you eat meat from factory farms, you partake in a system of cruelty, violence and evil. Always take sides. To be passive empowers the oppressor.
