Latest post Fri, May 2 2008 1:19 PM by sep. 23 replies.
Page 1 of 2 (24 items) 1 2 Next >
  • Thu, Apr 24 2008 3:30 PM
    • capnd
    • Posts 11
    • Points 145
    No beta deck control
    I am no longer able to obtain deck control of my BVW-D75 beta deck.  I have control of every other deck in our machine room but not the beta.  The other edit suites have control of this beta deck as well so I don't think it's a patch panel problem.  I have auto-configured and also selected "generic deck" in the deck configurations.  Video and audio signal is getting to the avid, just not the deck control. My RS 232 to RS 422 converter is working properly for all decks except for the beta.  The other editor here thinks that I can't get it to work because I am a girl but I don't think that's it since he can't get it to work either.  I have brought the deck into my edit suite to hook it up directly to the avid (using a different remote cable) and it's still not working.  I have deleted my MCState, Site_Attributes, and Site_Settings.avs in my settings folder and I have created new user settings and new projects.  I also upgraded to 2.7.7 from 2.5.2.  Nothing is working to get the avid to see the beta deck (all other decks still work).  I feel like I have exhausted all options but there must be something obvious that I am missing.
    My Configuration:  Avid Adrenaline running Media Composer ver. 2.7.7, HP xw8000 XP service pack 2, Xeon 3 GHz, 2 GB RAM
  • Thu, Apr 24 2008 3:56 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 5,095
    • Points 60,880
    Re: No beta deck control
     Rather than using auto-configure, do the configuration manually  - the channel on mine for Sony Betcam SX is "direct on COM1". And try the BVW-75 template instead of generic - it should work with your 75D.
    Media Composer Adrenaline PC v 2.7.7 * Newscutter Adrenaline PC v 6.7.7 * XDCAM PDW-1500 & PDW1 * PDZ-1 XDCAM Browser * Pixelan SpiceMaster 2.0 plug... [view my complete system specs]
  • Thu, Apr 24 2008 4:20 PM In reply to
    • capnd
    • Posts 11
    • Points 145
    I have tried this already but it still doesn't work.  It's only for this deck and I don't know why it decided to stop working.  This worked last week.  It's so weird.  I can see my other 2 beta sp decks, 2 digi beta decks, and 1 dv deck.
  • Thu, Apr 24 2008 4:21 PM In reply to
    • sep
    • France
    • Posts 5,583
    • Points 62,350
    capnd:
    OOOH !
    Can you connect the Beta deck directly to another computer with RS 232/422 control ? Or anything else that would control the Beta deck via RS 422 ?
    Can you swap the RS 422 cable ?
    Adrenaline MCA 2.8 XW8400 3Gb RAM DNxcel Board, 760 Gb striped SCSI media storage, 1.2 TB 4 X striped SAS 15 000rpm storage.----MC Soft 2.8 + Mojo HP XW8000... [view my complete system specs]
    sep
     Web site : www.audiacom.com
  • Thu, Apr 24 2008 4:28 PM In reply to
    • Blue Crow
    • Joined on Mon, Oct 23 2006
    • Posts 399
    • Points 4,885
     Does the BSP remote to any other machine directly ?
    xw8200 Avid Adrenaline version 2.7 , xw8000 Symphony 5.5.7 , Symphony Nitris dual boot DS versions 1.7.7 & 8.4 Lanshare Lp 4.2.3 , ISIS 1.4 [view my complete system specs]
  • Thu, Apr 24 2008 4:44 PM In reply to
    • Blue Crow
    • Posts 399
    • Points 4,885
    Does the deck function normally otherwise ? Can you record bars on it etc shuttle is it configured on the remote 9 pin in or out etc ?
    Ignore the problem being your a girl comment , dozens of times I've seen a big angry editor ranting about something not working only for a calm female assistant to come in and fix the problem.
  • Thu, Apr 24 2008 4:47 PM In reply to
    • capnd
    • Posts 11
    • Points 145
    It works directly with our other avids that have RS 232/422 and I have tried different cables.  I still cannot get it to work and I don't know why it would just stop working all of a sudden.
  • Thu, Apr 24 2008 4:50 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 12,641
    • Points 160,550
      Moderator: MCA Mac
    Try swapping your keyspan/rosetta adapter with one of the other bays. IF it doesn't work after that, download the latest drivers from whatever website is appropriate for your 422 device and see if maybe loading those shakes something loose.
  • Thu, Apr 24 2008 6:42 PM In reply to
    • sep
    • France
    • Posts 5,583
    • Points 62,350
    Blue Crow:
    Happened to myself, I have to agree.
    sep
  • Thu, Apr 24 2008 8:00 PM In reply to
    • Blue Crow
    • Posts 399
    • Points 4,885
    Have you had any luck capnd ?
  • Thu, Apr 24 2008 9:24 PM In reply to
    • capnd
    • Posts 11
    • Points 145
    No luck yet.  I actually started working on something else so I still have to try to reload drivers like BLKDOG suggested.  Thanks for all the help you guys!  I really appreciate it!  I'll update this post with any new results.
  • Thu, Apr 24 2008 11:25 PM In reply to
    • Blue Crow
    • Posts 399
    • Points 4,885
     Sorry I couldn't give you a fix .
  • Fri, Apr 25 2008 2:43 AM In reply to
    sounds like the deck is being a girl. Are you sure the deck is not just old and tired?
    HP XW8400 Dual, Dual Core; 4 TB Dulce RAID 5; 3GB Ram; XPRO (latest version); AJHD 1400; HP XW8400 Dual, Dual Core; 7 TB G-TECH RAID 5 (2 encl); 3GB... [view my complete system specs]
    Eating is a moral act. If you eat meat from factory farms, you partake in a system of cruelty, violence and evil. Always take sides. To be passive empowers the oppressor.
  • Fri, Apr 25 2008 1:52 PM In reply to
    • Blue Crow
    • Posts 399
    • Points 4,885
     I'm old and tired it's no fun.
  • Fri, Apr 25 2008 2:28 PM In reply to
    • sep
    • France
    • Posts 5,583
    • Points 62,350
     ...and how old are you ?
    sep
