Latest post Thu, Apr 24 2008 8:52 PM by hbrock. 3 replies.
  • Thu, Apr 24 2008 4:13 AM
    • BMW
    • Posts 42
    • Points 600
    Firewire problem/SDI Mojo.
    I am not getting anthything (video, Audio, deck control) throught the FW port in in the mojo.   Xpress pro is reconizing that the mojo is hooked up, Plus I am getting a component feed out of the mojo.  I am also getting analog auido from the mojo.   The only thing that I am not getting is anything via FW. I have tried it now on three different systems, but I am getting the same result. I have hooked up my standard mojo and everything works like a charm.  Therefore, I am not sure if I am missing something during set up of the SDI Mojo... Please any input would be great,  And yes I have the little green thing on the bottom all green :)
    I am think that there is something wrong with the mojo FW port.  The Mojo is only a month old and this would be the first time that I have tried using the Fw port.
  • Thu, Apr 24 2008 7:22 AM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 2,754
    • Points 31,475
    Re: Firewire problem/SDI Mojo.
    FW in or out?  SDI Mojos don't have a DV chip that enables simultaneous DV and analog outputs like the analog Mojo.  Also, the DV out doesn't do anything unless you're doing a Digital Cut (if you're using a recent release).
    MacPro, MacBook Pro and a Cube. The Cube doesn't do much but it looks cool. [view my complete system specs]
  • Thu, Apr 24 2008 4:03 PM In reply to
    • BMW
    • Posts 42
    • Points 600
    Thank you for that info, i did not know that.  However, Even if I try to do a dig cut/capture it doesn't  work.  I can not Config the deck.  I am using 5.8.0, is there another way that you are supposed to config the deck?
  • Thu, Apr 24 2008 8:52 PM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 2,754
    • Points 31,475
    Try selecting 1394 rather than DNA.  If that doesn't work, disconnect the Mojo and plug the deck into the native port on the CPU.
