Latest post Thu, May 1 2008 3:48 AM by Nik. 6 replies.
Page 1 of 1 (7 items)
  • Thu, Apr 24 2008 4:06 AM
    • Nik
    • New York
    • Posts 111
    • Points 1,380
    dvcpro & minidvhd
    Can I create a new project and load both dvcpro and minidvhd video into it? What project setting should I use?
    -Nik
    Dell Precision Workstation 670, dual xenon 3.2gh, 2g mem, nvidia quadro fx 1300 graphics card, windows xp pro, avid xpress pro 5.6.4. Lots of external... [view my complete system specs]
    "A Good Editor Never Sleeps"
  • Thu, Apr 24 2008 2:28 PM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 3,213
    • Points 36,860
    Re: dvcpro & minidvhd
    What is "minidvhd"?  If your question is really "can I load DVCpro and mini-DV in the same project" then yes you can.  Set the project up to match the playout format that you intend using.  You may have to do a mixdown or transcode to play out a mixed format timeline.
    MC 3.0 - Gigabyte GA-X38-DQ6 mobo - Intel core 2 Extreme Q6850 3 GHz - nVidia Quadro 1700 - 4 Gbyte mem - Internal 4 Tb SATA II 4-way RAID 5 array - Pyro... [view my complete system specs]
  • Fri, Apr 25 2008 2:48 AM In reply to
    Yes but DVCPRO and minidv are bascially the same SD format.
    Do you mean DVCPRO? DVCPRO 50? DVCPRO 100 (which is HD?)
    And for the other do you mean DV (aka mini-ev) or DVCAM? or HDV which is the consumer version of HD shot on a mini dv tape?
    HP XW8400 Dual, Dual Core; 4 TB Dulce RAID 5; 3GB Ram; XPRO (latest version); AJHD 1400; HP XW8400 Dual, Dual Core; 7 TB G-TECH RAID 5 (2 encl); 3GB... [view my complete system specs]
    Eating is a moral act. If you eat meat from factory farms, you partake in a system of cruelty, violence and evil. Always take sides. To be passive empowers the oppressor.
  • Fri, Apr 25 2008 5:21 AM In reply to
    • jwrl
    • Posts 3,213
    • Points 36,860
    Guywithcat:
    Yes, sorry.  I was thinking PAL there.  And I think that your guess about HDV is the most likely answer.
  • Sat, Apr 26 2008 10:32 PM In reply to
    • Nik
    • New York
    • Posts 111
    • Points 1,380
     Here's what I have to load into the same project: fugifilm DVCPRO, sony Mini DV and sony Mini DV HD. The Mini DV HD tapes are maroon and white and say HD. That's the only difference between my 2 Mini DV tapes. Thank you  in advance !
  • Tue, Apr 29 2008 5:04 PM In reply to
    What the tapes say does not matter. What matters is what you put on them. Do you know which camera you used?
  • Thu, May 1 2008 3:48 AM In reply to
    • Nik
    • New York
    • Posts 111
    • Points 1,380
     No, b/c the tapes are coming from different sources. I didn't shoot any of it and some of it is from 5 years ago. I did research and talked to other editors and I was told I should be fine with a 30i project setting but when I load in my hd video, change the setting inside avid to accomodate. Should work, right? What about when I export my project to sorenson squeeze? Do I have to do any sort of audio/video mixdown? Can I export a timeline with 2 different project settngs?
