Latest post Fri, Apr 25 2008 2:34 PM by Guywithcat. 5 replies.
Page 1 of 1 (6 items)
  • Wed, Apr 23 2008 5:47 PM
    3500 vs 1500 Video Card by NVIDIA
    So here is the scenario... We had the NVIDIA 1500 in our machine for a few weeks. We were getting video tearing on our monitors (not output to deck, just the monitors) when we edited DVCPRO HD native so we upgraded to the NVIDIA 3500. The problem is still there exaclty the same so it is probably from something else. Anyway, the new card was $1000. Frankly $1000 is more than we can afford to spend on something like this unless it is absolutely needed so we want to go back to the 1500 and return the 3500. To that end, is there any real benefit (besides theoretical) that we gain from having the 3500 over the 1500? We have until thursday to return the 3500 and I would like to do it unless there is a tangible reason not to? Thanks!
    HP XW8400 Dual, Dual Core; 4 TB Dulce RAID 5; 3GB Ram; XPRO (latest version); AJHD 1400; HP XW8400 Dual, Dual Core; 7 TB G-TECH RAID 5 (2 encl); 3GB... [view my complete system specs]
    I think we need a few more digital HD formats
  • Wed, Apr 23 2008 6:24 PM In reply to
    • raspago
    • FL, USA
    • Posts 894
    • Points 11,020
    • Moderator: Spanish Language
    Re: 3500 vs 1500 Video Card by NVIDIA
    .- None.
    Nothing at all.
    .- Return it now.
    Custom made Intel core 2 duo 2.4 (overclocked to 3.0) Nvidia 8800GS, 3GB Ecc Ram, E-MU 1212M Sound card, Sata Drives, Analog Mojo. [view my complete system specs]
  • Wed, Apr 23 2008 8:12 PM In reply to
     WOW THANKS
    out of curiosity, what is the difference? The 3500 was more expensive than the 1500
    we are retunign it
  • Wed, Apr 23 2008 9:29 PM In reply to
    • raspago
    • FL, USA
    • Posts 894
    • Points 11,020
    out of curiosity, what is the difference? The 3500 was more expensive than the 1500.
    .- It's a more powerful card, but for 3D intensive apps (3DSmax, Maya, Solidworks, Bentley, etc)
    No significant improvement for something like Avid (or another NLE).
    The 1500 is more than enough. Actually , It's even overkill.
    A Quadro FX560 will suffice.
  • Fri, Apr 25 2008 8:46 AM In reply to
    • indigospin
    • Lubbock, Texas, USA
    • Posts 358
    • Points 3,910
     raspago is correct.  i have the QuadroFX1300 - which last time i checked was the least expensive "avid certified" card.  works like a charm.  your original card (if you still have it) should be more than adequate.  video tearing IS probably system-related, though your system specs look pretty good.  possibly relatd to the raid-array connection speed? (assuming the video is housed there).
    good luck!
    shane
    ASUS M2N32-SLI Delux MOBO, AMD Athlon 64 X2 Dual-Core 4600+ 2.41 GHz, 3.5 GB RAM, Windows XP Pro SP2, NVIDIA QuadroFX1300 (driver 84.26... [view my complete system specs]
    staffer: "How do you go without sleep for so long?" me: "Not nearly as well as I used to."
  • Fri, Apr 25 2008 2:34 PM In reply to
    our first AVID raid is connected with sata 2. (Though something tells me it is sata 3?). We have a two enclosure Gtech Raid 5 on this machine. The enclosures are 4tb (3 bay) and 3tb (3 bay)respectively
    on the other AVID we have Dulce 4tb (4 bay), esata 2 also raid 5.
    All the machines tear. We have had a 3500 and 1500 and they both show video tearing in the PC monitor. Via FW for digital cut they do not show the tearing but, about 1 in 200 after effects imports stutter -- EVEN after a full video mixdown and brining everything to the minimum number of tracks.
