Latest post Wed, May 7 2008 12:26 AM by teddylevy. 38 replies.
Page 1 of 3 (39 items) 1 2 3 Next >
  • Wed, Apr 23 2008 4:00 PM
    • camoscato
    • Posts 4,393
    • Points 52,445
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    Xpress Pro 5.8.3 Now Available
     Xpress Pro 5.8.3 is now available.  This is a Customer Patch Release.  A CPR is an update for Avid products intended to address specific problems. Because CPR testing involves a limited test cycle, CPRs should only be used when a customer’s specific issue has been resolved in that respective CPR.
    If you are unsure whether a specific CPR addresses your issue, check the accompanying release notes for verification. If the release notes do not mention a specific issue, contact Avid Technical Support, your Avid Account representative, or local Avid reseller prior to installing the software.
    CPR updates are cumulative - the current CPR includes all prior updates. Installation of CPR software components may result in loss of data, loss of media, or other system problems.
    Requirements
    These releases are for software-only, Avid Adrenaline™- and Avid Mojo® SDI-based systems running on Intel- and PowerPC-based Macs and PCs.  The new 5.8.3 CPR, includes support for Mac OS X 10.4.11, QuickTime 7.3, the Microsoft VC-1 codec, and Avid Interplay 1.2.3 (Windows). Additional enhancements are detailed in the ReadMe documentation found on the Avid Knowledge Base. Avid recommends customers read this documentation before using any new software version.
    Availability
    Customer Patch Releases are available from the Avid Download Center at no charge to active Avid Support Contract customers and any customers that are running 5.7.x or higher and are entitled to the 5.8.3 editor.  For those that do not have a download center account, go here:  http://www.avid.com/support/downloadcenter/accountRequest.asp
    Note that customers will only be able to see the products listed on the download center that they are entitled to based on registration and/or support contract status.
    MC 3.0, HP dv9605ea, Vista Home Premium, AMD Athlon 1.8 GHz, 2 GB RAM, nVidia GeForce 7150M, Conexant HD Audio [view my complete system specs]
  • Thu, Apr 24 2008 12:48 AM In reply to
    • John Mac
    • Posts 86
    • Points 1,050
    Re: Xpress Pro 5.8.3 Now Available
     Hi, looked on CPR but no sign of 5.8.3 yet?
    thanks
    JM
    Windows XP P4 3.4Ghz PCI board 1 AGP slot with nvidia FX1100 card 3Gb ram X-fi audio card SSCI x2 external Avid firewire hard drive Internal 80Gb... [view my complete system specs]
  • Thu, Apr 24 2008 12:56 AM In reply to
    Hi. I'm using 5.8 Academic and for the first time I received an e-mail announcing this CPR release. It's the first time I've had a notification such as this and I don't know what it exactly means, and whether I'm able to use 5.8.3?
    I never received any e-mails about previous version updates/upgrades/revisions, so this is kinda new to me. Any clarification would be greatly appreciated.
    Thanks.
    MSI Neo-2 Platinum Nforce3 Ultra (Bios Rev 1.0D) Athlon64 X2 4200+ (Overclocked to 2 x 2.4GHz) AMD Cool'N'Quiet CPU Throttling 2GB Corsair PC3200... [view my complete system specs]
  • Thu, Apr 24 2008 1:47 AM In reply to
    Register your dongle.
    Then request for a account to the Avid Download Center. The CPR will be there for you to download.
  • Thu, Apr 24 2008 1:54 AM In reply to
    • gaspar
    • Posts 12
    • Points 140
    I got the same email, too. Don't see the point, however, if the download isn't there. Why not post the download, THEN send me an email?
  • Thu, Apr 24 2008 2:00 AM In reply to
    Avid is consolidating the Download Center. All updates will be moved to the Download Center instead of the CPR. So I will repeat what I posted previously - register, request, download.
  • Thu, Apr 24 2008 2:10 AM In reply to
    • gaspar
    • Posts 12
    • Points 140
    I HAVE registered. I've BEEN to the download centre. It's not there.
    Avid thoughtfully provided a link in the email, sending me to look for a download that's not there. New thinking?
  • Thu, Apr 24 2008 2:38 AM In reply to
    gaspar:
    OK. I assumed you where looking in the CPR section instead of the login Download Center. Apologies. Contact support to check your Download Center account to make sure you it is correct.
  • Thu, Apr 24 2008 2:58 AM In reply to
    • Avid Technology Inc.
    • Posts 650
    • Points 8,955
    Gaspar
    it is there and has been since yesterday......  sign in http://esd.avid.com/Login.aspx?ReturnUrl=%2fDefault.aspx and click on Avid Xpress Pro Family - 3rd from bottom.  5.8.3 is at the top.
    marianna_montague@avid.com
    813-493-6800
    AOL IM avidmarianna
  • Thu, Apr 24 2008 3:16 AM In reply to
    • gaspar
    • Posts 12
    • Points 140
    Thank you Dom and Marianna for your replies. Much appreciated, but:
    The link in the email Avid sent me leads me here:
    http://www.avid.com/support/downloadcenter/index.asp
    On the page it says:
    "Additional Support Updates on Avid.com
    Customers who do not have a valid Avid support contract can access support updates by selecting the appropriate product below."
    I click on Avid Xpress Pro .5.8, which is the closest thing to the upgrade I am looking for. It says congrats, I'm registered and can download the file. Which, unfortunately, is not the right file. So the email Avid sent me leads me to the wrong page.
    You kindly provide me with another link, which asks me to login. It tells me the email address I enter does not exist in the system, even though it seemed to exist well enough for Avid to send me an email leading me to the wrong place. And I'm registered on Avid and have downloaded updates before. But at this new link, I suddenly don't exist.
    I mean, come on! Is it because I don't have a support contract? It doen't say anything about that in the email.
    Thanks. I'm just frustrated that it should be easier. I DO appreciate you taking the time to reply. Very good of you both.
  • Thu, Apr 24 2008 3:20 AM In reply to
    • gaspar
    • Posts 12
    • Points 140
    Okay, so now I notice that the first post in this thread, which is almost a carbon copy of the email I received, has updated links, and a link to sign up for the download center (which does not exist in the email.). Sheesh.
  • Thu, Apr 24 2008 3:23 AM In reply to
    • highfly900
    • Portland, OR
    • Posts 59
    • Points 775
    new thinking is confusing!
    so let me get this straight, i need to have an account for the Avid forums, I need a seperate account for the Avid knowledge base and need a THIRD!?!? to use the download center?
    is this correct or am i really lost?
    3.0 Ghz Quad Mac Pro OS X 10.4.11 2GB RAM ATI 1900 MC 2.8 [view my complete system specs]
    -danimal the animal
  • Thu, Apr 24 2008 3:48 AM In reply to
    • bobcat
    • Joined on Thu, Jul 20 2006
    • New Mexico, USA
    • Posts 188
    • Points 2,200
    Come on Avid. Why do you guys continually make this so complicated. This is not new thinking, this is same old, same old.
    All I wanted to do is read the new Readme file. I couldn't even do that without going through extra steps.
    Man, this is so frustrating when it is suppose to be better (simple) customer support.
    (System #1)HP 8200,dual 3.4,quadro 1400, 2gb ram, 160gb boot drive, 250gb Sata internal, 250gb Gtech USB archive drive. Avid MC 3.0 (System #2)Macbook... [view my complete system specs]
  • Thu, Apr 24 2008 4:17 AM In reply to
    "All I wanted to do is read the new Readme file. I couldn't even do that without going through extra steps."
    If you only want the docs, go to the Knowledge Base.  The following took 15 seconds to locate:
    http://tinyurl.com/4a7zho
    I chose Avid Xpress Family > Xpress Pro > All > 5.8.3
    Media Composer 3.0 w/Mojo (analog), HP xw8400, 1xQC 3.0GHz, 4GB RAM, FX 3700, 500GB Boot, 1x1TB & 1x500GB internal SATA media drives (temp), 2xHP L2245w... [view my complete system specs]
  • Thu, Apr 24 2008 10:18 AM In reply to
    "... For those that do not have a download center account, go here:  http://www.avid.com/support/downloadcenter/accountRequest.asp ..."
    camoscato,
    The form is unclear in regards to which Id's to provide. The instrucitons clearly mention both Dogle ID and System ID, but there are only spaces for System ID. Can you clarify what we should enter, and maybe have the form clarified?
    Thanks much.
    P.S. As anside, I've posted, PM'd and emailed concerning support for Canon's 24F format to no avail. Can you PLEASE let me know what I have to do to get some idea of Avid's plans concerning 24F? Thank you VERY MUCH.
    P4 3.0. 2 Gig RAM, CAS 2.5. Intel 865PERL mobo. Two WD 7,200 IDE drives and two WD Raptor 10,000 SATA drives--no RAID. nVIDIA Quadro FX 1100. Two EIZO... [view my complete system specs]
