Latest post Mon, Jun 9 2008 4:50 PM by Marianna. 68 replies.
Page 3 of 5 (69 items) < Previous 1 2 3 4 5 Next >
  • Sun, Apr 27 2008 4:36 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 3,457
    • Points 39,975
    Re: Media Composer v2.8.3 / NewsCutter v2.8.3 Released
    angeleye:
    When I tried to login with what I thought would be a good password, they reset my password and sent me a new one.
    That was my experience too, except that I had been sent a log-in password.  I attempted to use it, failed, then received not one but two more emails fortunately both with the same new password, which worked.
    I guess there are quite a few wrinkles in the system.
  • Mon, May 12 2008 1:54 PM In reply to
    • cassano
    • Washington, DC
    • Posts 205
    • Points 2,590
    I work in a shop where up to 70 editors may create user settings (it's never been that many, but it could in theory).  I'm currently testing v2.8.3 on my machine only and ran into a display bug that I'm not sure existed in earlier versions, or if it's exclusive to v2.8.3.  I've never seen it before so I'll put the bug report in this thread.
    If there are exactly 36 user settings on the PC, the user settings pulldown in the Project Select box will severely truncate to only about 5 or 6 characters wide.  If it's 35 or below, the pulldown operates normally.  If it's 37 or more, the pulldown correctly wraps to create another column.
    Even with 36 users, once inside the application, the user settings pulldown in the Project Window worked fine.
    xw8400 w/4Gb RAM / NVIDIA Quadro FX 1500/ MCA v2.8/ Unity LANshare EX v4.1.5 [view my complete system specs]
    Filed under: ,
  • Mon, May 12 2008 2:52 PM In reply to
    Never had that many editors, but I'll mention it to Avid.
    As a workaround, you could create subfolders and group editors by name; i.e., A-F, G-K, etc. and then you'd limit each folder to less than 36.
    MacPro Symphony Nitris DX (v3.0), MacPro MCA HD (v3.0), Mac Meridien (v12.1.2), Unity LanShare EX (v4.1.6) [view my complete system specs]
  • Mon, May 12 2008 3:30 PM In reply to
    • cassano
    • Washington, DC
    • Posts 205
    • Points 2,590
    Actually, I posted the easiest workaround.  Either delete an unused user setting, or just create a dummy user setting.  In other words, do something so that you don't have exactly 36 settings.
  • Mon, May 12 2008 3:39 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,752
    • Points 174,300
    YOu can also nest your users in folders to get around  the 36 File problem. We used to have a folder for day editors or a folder for night or even by project.
  • Mon, May 12 2008 5:00 PM In reply to
     We have some "older" machines here that were purchased in 2006 they currently are running Avid Express. We were told by our sales person that they would run Media Composer 2.8.3.
    Do you have a list of System specifications required for 2.8.3 so that I can verify this??
    BTW, these are PC's not Apple products.
  • Mon, May 12 2008 5:03 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,752
    • Points 174,300
    Are you talking about Avid Express or Xprress 'Pro? 'Cause I'm pretty sure that any CPU qualified to run Avid Xpress is way too far out of date for any of  the software only versions.
    PC specs can be found on the avid.com/products page of this site.
  • Tue, May 13 2008 4:42 PM In reply to
    BLKDOG:
     I believe that it is Xpress 'Pro.
    Here are the system spec of our existing machines.
    3.20 GHz Xeon CPU
    2 GB RAM
    nVidia Quadro FX 1400
    2 - 250GB HDD
    XP Pro
    48X/32XCDRW 16XDVD+/-RW
    2 - 19in FlatPanel Monitors
  • Wed, May 21 2008 1:44 AM In reply to
    • daktulus
    • Posts 370
    • Points 4,915
    I sent my information for the log-in 2 days ago- no answer at all.
    Dell650, 2.8Ghz, 3 GB RAM, FX500, 5 SCSI HDDs, Mojo. Dell Precision M90, Core2Duo 2.16Ghz, FX1500, SATA 7200rpm Media Composer 3.0 [view my complete system specs]
  • Wed, May 21 2008 1:47 AM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,752
    • Points 174,300
    It may take a little longer. They are swamped with registrations. If it goes more than a week, let me know and we'll get into it.
  • Wed, May 21 2008 1:53 AM In reply to
    • daktulus
    • Posts 370
    • Points 4,915
    More than a week, are you kidding? These downloads used to be available immediatly. Great improvement.
  • Wed, May 21 2008 3:22 AM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,752
    • Points 174,300
    They are available immediate when you are registered. Unfortunately the system for registration has been very clogged with overwhelming demand. I didn't say it would be a week but, if you don't hear by then, we can make sure you haven't fallen through the cracks.
  • Wed, May 21 2008 4:08 AM In reply to
    • Editsmith
    • Australia
    • Posts 30
    • Points 420
    BLKDOG:
    Customer Patch Releases are available from the Avid Download Center at no charge to active Avid Support Contract customers and any customers that are running x.7.x or higher and are entitled to the x.8.3 editors.
    I wish Avid would sort this out.. I upgraded to Composer 4 days ago.. applied to the Download centre and have been told I'm not elidgible for access.. which is interesting as i'm entitled to a free version 3 when its released.. anyone have any idea how ill be getting that?
    ASUS P5WD2, Pentium D940, 2 GIG Corsair RAM, BFG GT6600 Vid Card, OnBoard Firewire, 2 x Samsung 940MW, Soundblaster Audigy, Media on Maxtor USB Hard Drives... [view my complete system specs]
  • Wed, May 21 2008 12:06 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,752
    • Points 174,300
    Did you get your registration password from avid after you registered with the DL canter? It's taking them a while to get them all out. You'll probably have it in a day or so.
  • Thu, May 22 2008 5:31 AM In reply to
    • Editsmith
    • Australia
    • Posts 30
    • Points 420
    BLKDOG:
     no I got an email from  Jesse saying I wasn't allowed access as I didn't have a support contract.. when I challenged her on that she now wants me to provide proof of purchse of the upgrade. I realise you guys are having teething problems but seriously - I only bought it a week ago... I am wondering why I am providing this when it clearly states I can have vers 3 when its available..
    of course getting it is another thing without download centre access..
