Here are My Sys Specs:
Dual Xeon pcie workstation Avid Base/1.44/160/cdrw/dvdrw/kb/mouse
hitachi deskstar 250gp sata150 7200rpm 8mb cash drive
nvidia quadro fx540 pci professional video card
1 2 gb kit ddr2-400 ecc registered ram
2 intel xeon3.2ghz 2m of l2 cache/800mhz/604 pins processor
2 viewsonic vg920 19" silver black 1280x1024 display
1 windows sys config and testing
My Problem is this im in the middle of a job recently i had a client that required that i and my partner take our desktops to their site. ( A Mistyake I Wont MAke Again )
any hew we wound up going on line to test out communications between my sys and group member systems. i got a virus in the form of a box looking for permission for acess to the web.
i found out later that each time the box poped up it did something to the regestry
so i had to uninstall / reinstall my soft ware bad scean i hope no one else goes on the journey i went on. I any event i got back up and running ( Sort of ) with a few issues.
now i come to my current problem i loaded sound soap on my sys it showed up in the audio suite tool as a plug in. the sound soap didnt work like i had hoped so i controle zed and went on to try another option. ZOUNDS a box comes up acess violation avid has a fatle error arrrgh! My Baby Is Hurt And Bad.
What do i Do? Who Can Help Me? Do i Uninstall All Of The Avid Ware and Reinstall? Is This An Issue Of The Dongle? Is It Damaged? Fortunatly I Saved My Work To TApe ( See It HAs Its Useses) But Im In The Middle Of Getting A Teleproduction ready for air so feed back is very important.
Guydell B. MAxfield II
Soundsoap will not work as a plug-in for Avid - it can only be run as a stand-alone program. It will show up in the audio effects pallette, but will not work properly and will only cause problems.
If you got hit with a virus that corrupted the registry, you may need to do a complete re-install of OS and applications if you are still having problems since you don't know the full extent of the damage that the virus caused.
Thanx For The Info I Will do as you suggest im saveing my oms files in the hopes i will be able to preserve the project as it is now. or can i pull it from my hd to disc as it is now i have drag n drop ability
