Latest post Thu, Apr 24 2008 4:20 AM by Prof. Morphious. 2 replies.
  • Wed, Apr 23 2008 3:31 AM
    Is This A Dongle Problem
     Here are My Sys Specs:
    Dual Xeon pcie workstation Avid Base/1.44/160/cdrw/dvdrw/kb/mouse
    hitachi deskstar 250gp sata150 7200rpm 8mb cash drive
    nvidia quadro fx540 pci professional video card
    1 2 gb kit ddr2-400 ecc registered ram
    2 intel xeon3.2ghz 2m of l2 cache/800mhz/604 pins processor
    2 viewsonic vg920 19" silver black 1280x1024 display
    1 windows sys config and testing
    My Problem is this im in the middle of a job recently i had a client that required that i and my partner take our desktops to their site. ( A Mistyake I Wont MAke Again )
    any hew we wound up going on line to test out communications between my sys and group member systems. i got a virus in the form of a box looking for permission for acess to the web.
    i found out later that each time the box poped up it did something to the regestry
    so i had to uninstall / reinstall my soft ware bad scean i hope no one else goes on the journey i went on. I any event i got back up and running ( Sort of ) with a few issues.
    now i come to my current problem i loaded sound soap on my sys it showed up in the audio suite tool as a plug in. the sound soap didnt work like i had hoped so i controle zed and went on to try another option. ZOUNDS a box comes up acess violation avid has a fatle error arrrgh! My Baby Is Hurt And Bad.
    What do i Do? Who Can Help Me? Do i Uninstall All Of The Avid Ware and Reinstall? Is This An Issue Of The Dongle? Is It Damaged? Fortunatly I Saved My Work To TApe ( See It HAs Its Useses) But Im In The Middle Of Getting A Teleproduction ready for air so feed back is very important.
    Here are My Sys Specs:Dual Xeon pcie workstation Avid Base/1.44/160/cdrw/dvdrw/kb/mousehitachi deskstar 250gp sata150 7200rpm 8mb cash drivenvidia quadro... [view my complete system specs]
    Guydell B. MAxfield II
  • Wed, Apr 23 2008 3:39 AM In reply to
    • vpcmike
    • Baltimore, MD
    • Posts 985
    • Points 11,655
    Re: Is This A Dongle Problem
     Soundsoap will not work as a plug-in for Avid - it can only be run as a stand-alone program.  It will show up in the audio effects pallette, but will not work properly and will only cause problems.
    If you got hit with a virus that corrupted the registry, you may need to do a complete re-install of OS and applications if you are still having problems since you don't know the full extent of the damage that the virus caused.
    System #1 -Tyan i7525 MB, dual 3.2 Xeon, 4 GB Ram, Mojo, Quadro 3500, Pyro 64 FireWire, 6 TB Unity System #2 - Intel 7505VB2 MB, Dual 2.8 Xeon, 2 MB... [view my complete system specs]
  • Thu, Apr 24 2008 4:20 AM In reply to
     Thanx For The Info I Will do as you suggest im saveing my oms files in the hopes i will be able to preserve the project as it is now. or can i pull it from my hd to disc as it is now i have drag n drop ability
