Latest post Sun, Apr 27 2008 11:10 PM by yamaaaaar. 19 replies.
Page 1 of 2 (20 items) 1 2 Next >
  • Tue, Apr 22 2008 10:50 PM
    • yamaaaaar
    • Joined on Thu, Jan 24 2008
    • Posts 24
    • Points 270
    avid 5.8 Buffer overrun error
     I have recently upgraded to avid 5.8 but when i do anyting with the video..a transion or colour corect effect for example it gives me the message "buffer overrun" and terminates the programe!
    I have read elsewere in the frorm of people having the same problem but it didnt seem to have a soloution!
    Has ahnyone come across this before and maybe has a idea waht is causing it?
    Would be greatfull for any feedback
    Cheers
    Andy
  • Wed, Apr 23 2008 8:27 AM In reply to
    • camoscato
    • Posts 4,686
    • Points 55,860
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    Re: avid 5.8 Buffer overrun error
    Hi Andy,
    In order to help you, we need to know your system specifications.  After you've posted them, reply to this thread and let us know and we'll see what we can figure out.
    good luck,
    Carl
  • Wed, Apr 23 2008 1:54 PM In reply to
    • yamaaaaar
    • Posts 24
    • Points 270
    Hey there...Ok here are my specs!
    Version of avid- Avid HD xpress 5.8
    computor- Dell precision690
    Intel xeon(R) cpu
    2.gb ram
    Quicktime 7.3
    Graphics card- nividia quadro fx 3500
    driver- 91.85
    hope you can help
    Andy
  • Wed, Apr 23 2008 9:10 PM In reply to
    • Baklap
    • Hilversum - The Netherlands
    • Posts 6,625
    • Points 78,505
    From what version did you upgrade?
    Menno
    Test-Intel Core2Duo 6800,GTS8800 Nvidia (soft modded into Quadro FX4600),Soundblaster Live 5.1, 21" Samsung display [view my complete system specs]
    Dutch AV forum
  • Wed, Apr 23 2008 10:44 PM In reply to
    • yamaaaaar
    • Posts 24
    • Points 270
     I updated from avid xpress pro 5.7
  • Wed, Apr 23 2008 11:08 PM In reply to
     Did you uninstall 5.7 prior to installing 5.8? Trash MCSTATE?
    MC 2.8 w/Toolkit Dell Precision 650 2.4 GHz Dual Xeon 2gb RAM Nvidia FX 1000 4-Baracuda 50Gb SCSI internals in RAID -0 120 GB Lacie D2 FW-400 External [view my complete system specs]
    Greg Baker
  • Thu, Apr 24 2008 12:58 AM In reply to
    • yamaaaaar
    • Posts 24
    • Points 270
     i did un-instal 5.7 1st yes ..what is Trash mcstate?
  • Thu, Apr 24 2008 10:00 PM In reply to
    • yamaaaaar
    • Posts 24
    • Points 270
    Still not working..ive been scoweing the internet to no avail.
    Anyone got any ideas?
    Andy
  • Fri, Apr 25 2008 9:46 AM In reply to
    • indigospin
    • Lubbock, Texas, USA
    • Posts 358
    • Points 3,910
    he means to delete the file "MCState" & allow it to rebuild.  MCState is a settings file that can become corrupted (for reasons known only to the computer gods).  deleting it (only when Avid is not running!) will cause Avid to rebuild it the next time you launch avid & enter a project.
    i's been a while (thankfully), but i believe it can be found in  c:/program files/avid/avid express pro/settings
    backup the file to your desktop & if rebuilding it has no effect on your problem, you can just restore your old settings (if they have changed at all).  the file "Site Settings" is another file that can become corrupted.  you can rebuild it in the same way, but your customized user settings (toolbar & window positions, etc) will be reset to the default.  i doubt the site settings have anything to do with a Buffer Overrun error... but it can't hurt to try before you proceed with a complete UNinstall/REinstall.
    good luck.
    shane
    ASUS M2N32-SLI Delux MOBO, AMD Athlon 64 X2 Dual-Core 4600+ 2.41 GHz, 3.5 GB RAM, Windows XP Pro SP2, NVIDIA QuadroFX1300 (driver 84.26... [view my complete system specs]
    staffer: "How do you go without sleep for so long?" me: "Not nearly as well as I used to."
  • Fri, Apr 25 2008 12:14 PM In reply to
    • yamaaaaar
    • Posts 24
    • Points 270
     Thanks for that shane!
    But am still a bit unsure what to do now? Do you think its the Mcstate file that is causing the problem or should i do a unintal then reinstal 1st..what would be the most logical order of action?
    Andy
  • Sat, Apr 26 2008 1:53 AM In reply to
    • indigospin
    • Posts 358
    • Points 3,910
    i would try rebuilding the setting files first, because they will be reset to defaults anyway if you uninstall/reinstall.
    shane
  • Sat, Apr 26 2008 1:11 PM In reply to
    • yamaaaaar
    • Posts 24
    • Points 270
     Have tired deleting that file..still no joy!
    Going to try uninstall and re install but dubous thats is going to work!
    Is it not maore likely to be a setting of some type?
    Help Avid froum...!
    Andy
  • Sat, Apr 26 2008 1:31 PM In reply to
    • yamaaaaar
    • Posts 24
    • Points 270
     Have unintalled and reinstalled that didnt help either...what now?
    Im out of ideas...help.....Andy
  • Sat, Apr 26 2008 1:38 PM In reply to
    • Baklap
    • Posts 6,625
    • Points 78,505
    Give us a complete set up overview:
    System, memory, drives, firewire apps, usb apps, external drives etc.. everything you can think of.
    Menno
    Dutch AV forum
  • Sat, Apr 26 2008 2:31 PM In reply to
    • yamaaaaar
    • Posts 24
    • Points 270
     I have put most of the system informaton above
    I am running 2 Lacie fire wire drives ofr it for the media
    running windows xp pro on a dell 690 precission..with quad core dual proccers i think?
    2 gb of ram...
    system drive has 40gbwith lots of space remaining
    errr anything else?
