hi sir
the error message is
An object could not be found on the server, probably someone else deleted it.
please refresh your view and try again -Dissmiss.
NOTE:- But the particular object still on server and nobody is deleted,but its shows above error.
here i am sending you the image of error.
please find out.
t&r
Hi: are you sure nobody deleted the file from the workspace via windows?, also, is the workspace mounted in the Media Indexer?
Regards
Felipe Gonzalez
ACSR Interplay
Avid Latin America
El cerebro es como un paracaídas, trabaja mejor cuando se abre / Brain is like a parachute, it works better when it is open
Which version of Interplay are you using? I believe this behavior has been fixed in the most recent release.
Via windows mxf files are deleted but in access through interplay its showing error
