Latest post Mon, Jun 23 2008 9:18 PM by kishore. 3 replies.
  • Tue, Apr 22 2008 6:34 AM
    • kishore
    • Joined on Tue, Nov 6 2007
    • Posts 6
    • Points 65
    Embarrassed [:$] while delition form interplay access some clips showing error message
     hi sir
    the error message is
    An object could not be found on the server, probably someone else deleted it.
    please refresh your view and try again -Dissmiss.
    NOTE:- But the particular object still on server and nobody is deleted,but  its shows above error.
    here i am sending you the image of error.
    please find out.
    t&r
  • Tue, Apr 22 2008 1:20 PM In reply to
    Re: while delition form interplay access some clips showing error message
    Hi: are you sure nobody deleted the file from the workspace via windows?, also, is the workspace mounted in the Media Indexer?
    Regards
    Felipe Gonzalez
    ACSR Interplay
    Avid Latin America
    El cerebro es como un paracaídas, trabaja mejor cuando se abre / Brain is like a parachute, it works better when it is open
  • Wed, Apr 23 2008 4:59 AM In reply to
    • lawsonr
    • Joined on Thu, Jun 8 2006
    • CBS News
    • Posts 144
    • Points 1,745
    Which version of Interplay are you using? I believe this behavior has been fixed in the most recent release.
    Avid NewsCutter Adrenaline 6.8.3, ISIS 1.4, Interplay 1.2.3. [view my complete system specs]
  • Mon, Jun 23 2008 9:18 PM In reply to
    • kishore
    • Posts 6
    • Points 65
     Via windows mxf files are deleted but in access through interplay its showing error
