Latest post Tue, Apr 22 2008 5:38 PM by Randall L Rike. 4 replies.
  • Tue, Apr 22 2008 1:49 AM
    • dingo1
    • Grinnell
    • Posts 158
    • Points 1,935
    Macdrive 6 issue
    I just installed macdrive 6 cause I was told I needed it on my PC to see this G-Drive mini I have in my hot little hands (with many important files no less).  I have had macdrive 5 in the past with no problems, but with 6 I get a flag asking about each of my 40 lanshare drives and whether I have any mac information on these PC'ed drives.  Many "cancels" later I have to turn Macdrive 6 off to keep it from doing this every 5 minutes.  Is there a preference file I need to change...something obvious that wasn't in macdrive 5.  Thanks in advance to all.
    Cheers
    Gregg G
    8200 3 gigs ram MCA 2.7 lanshare on fibre interplay 1.1
    2 PC NCA 6.8 on lanshare 1Mac MCA 2.8 on lanshare 1 Symphony Nitris classic 3.0 Passel full of PC express pros on Dells 1 express pro on macbook pro [view my complete system specs]
  • Tue, Apr 22 2008 1:54 AM In reply to
    • ravidedit
    • Joined on Mon, Oct 24 2005
    • Los Angeles, CA
    • Posts 647
    • Points 8,095
    Re: Macdrive 6 issue
    you need MacDrive crossstripe to work with Unity.  Was the version 5 the cross stripe edition?  if you are using the regular mac drive it will keep doing that and be in danger of intializing the unity drives and erasing everything on them
    Mine: Custom Built AMD 64 3200+/socket 939 2 GB RAM Nvidia 6600gt MC 2.7 Soft Work: dozens of Mac Meridiens, PC and Mac Adrenalines, Unity, Lanshare... [view my complete system specs]
  • Tue, Apr 22 2008 2:05 AM In reply to
    You also might want to upgrade to MacDrive v7.
  • Tue, Apr 22 2008 5:09 PM In reply to
    • dingo1
    • Grinnell
    • Posts 158
    • Points 1,935
    I notice there is a macdrive 7 and a macdrive 6 crossstripe..I take it I need the cross stripe version for my lanshare environs...but I am curious why the macdrive 5 version worked fine in the lanshare but 6 does not....is it possible there is a setting in 6 or am I destined to move to 6 cross stripe  (OK I am cheap 6 was 50 bucks...cross stripe is 250...guess I try the demo version).  Thanks for your help guys...off to download land.
    Gregg G
  • Tue, Apr 22 2008 5:38 PM In reply to
    CrossStripe is only required for "seeing" striped drives, e.g. striped SCSI arrays.  Unity drives are not striped, not are they host-platform specific in their formatting.  The older versions of MacDrive saw the "raw" drives in the Unity system, and didn't know what to do with them.
