Any one knows what is this? I am connecting component out to client monitor and world clock to Horita black box for zync. Sometimes I can see the client monitor sometimes the Mojo is totally off. I can't digitize anything (DV or HDV) it doesn't find the camera (Sony HDV V1U).
Error in the composer window with black BG and in white reading: "A device on the 1394 bus causing Problems. -FTStavs Code-FT_LinkInitiazingFailed-Flamethrower Link Manager :: OpenLink Failed to create Link object.
When we close this particular project (DV or HDV) and when opening a new project to see if there is a difference (we have DV and HDV projects, 24p, 30i, etc) we get this sign that says:
Avid Media Composer
Exception:DVAudio_Manager_LAVA_EXECUTE_ERROR
The HP Workstation has 2GB of RAM, is DUAL 3.4 and has worked just fine with AMC before this Mojo (no other Mojo). We need to be able to playback HDV and DV and IO material from this HDV camera and professional VTRs.....Reintall HP from scratch...what else can we do?
Do you use seperate buses from the MOJO and the DECK?
Hi Israel, please help me learn where do I find the buses and also if you think using the Ethernet for internet , having only two 1394 in this computer from factory, it is OK to use it with the Mojo SDI? I am using an HDV camera as my deck. Thanks!
