Latest post Mon, Apr 21 2008 2:58 AM by Larry Rubin. 3 replies.
  • Mon, Apr 21 2008 2:42 AM
    • Rehd Blob
    • Joined on Mon, Apr 21 2008
    • Posts 1
    • Points 35
    HELP with Stop Motion
    I'm a new user to Avid Free DV and I'm trying to get it to do stop-motion. Unfortunately, I'm really bad at using it; I can't get much to work. I want to know how to:
    1. Put frames into the timeline and adjust to a constant framerate UNDER 1 second
    2. Be able to move frames around on the timeline.
    3. And any other things relevant to making stop-motion with Avid Free DV.
    Thanks!
    [Subject line edited by moderator]
  • Mon, Apr 21 2008 2:58 AM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 4,203
    • Points 50,470
    Re: HELP!!
     OK I'm on Composer, not Free, but I'm assuming you mean "How do I create a freeze frame?"
    Park the source monitor on the frame you want to freeze and check the clip pull down menu for "freeze frame". Pull down to it and define the length of the freeze frame clip that will be created. There are also frame options in case your freeze frame gets "the jitters".
    Segment editing (the red and yellow arrow keys) allow you to move clips around on the timeline. The red one lifts and overwrites at the new position, the yellow one extracts and inserts clips in the timeline. CTL + drag snaps to an in point, CTRL + ALT + drag snaps to an out point. ALT dragging moves one frame at a time. To move clips vertically to a different track without any horizontal movement (vertical constraint) CTRL + SHIFT drag.
    Media Composer Adrenaline PC v 2.7.7 Newscutter Adrenaline PC v 6.7.7 Pixelan SpiceMaster 2.0 plug-in Sapphire 2.05 plug-in (single platform) Windows... [view my complete system specs]
  • Mon, Apr 21 2008 6:47 AM In reply to
    Re: HELP!!
    Please review all these Free DV tutorials, and then come back with questions ...
    http://www.avid.com/products/freedv/tutorials/index.asp
    Also, you might want to modify your subject line to be somethig other than HELP.  Everybody posting here needs help.
    Media Composer 3.0 w/Mojo (analog), HP xw8200, 2.5GB's, FX 1300, dual HP L2245w 22" monitors, 160GB Boot, 1 x 1TB internal SATA media drive, 2... [view my complete system specs]
  • Mon, Apr 21 2008 6:51 AM In reply to
    • camoscato
    • Posts 4,120
    • Points 49,425
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    Re: HELP!!
    Take a look at the FreeDV tutorials, which will help get you going.  Tutorial 9 tells you how to move material around on the timeline, and Tutorial 12 tells you how to work with effects.  The Motion Effect is the one you want for changing the speed of clips.
    good luck,
    Carl
