Latest post Fri, Apr 18 2008 11:45 PM by Wm.Busby. 6 replies.
Page 1 of 1 (7 items)
  • Fri, Apr 18 2008 5:50 PM
    • maccorm
    • Joined on Fri, Apr 18 2008
    • Posts 13
    • Points 165
    Pansonic P2 footage playing back too fast in Avid
     Hey there...
              Im trying to import footage shot on a Panasonic P2 to Avid. It was shot 720 30pn over 24 frams per seconds to try and match all the other cameras we were using to shoot a live DVD for a band.
             When I import the MXF files with the Media Tool on MC 2.81, the only project setting it will work with is 720 29.97 HDV OR 30i. All others tell me I can't view the 29.97 footage unless it matches the project file, which all makes sense.
              But the problem is the footage looks like its sped up about %25 too fast when I play it back. I've tried to sync it with the audio, and it is obvious it is too fast. Im really confused why something shot at 30pn over 24 fps will play back so fast....it doesn't make sense to me. I have tried it on 2 different avids with the same results.....Anyone have any solutions?
    Thanks!
  • Fri, Apr 18 2008 6:56 PM In reply to
    Re: Pansonic P2 footage playing back too fast in Avid
     You shot 30pN with the framerate at 24? That would mean you undercranked and it turned it into fast motion video. If you wanted regular motion you should have shot 30pN with the framerate at 30.
    Formerly known as HDRebel88
  • Fri, Apr 18 2008 7:01 PM In reply to
    • maccorm
    • Posts 13
    • Points 165
     That's what I thought....but our DP assured us that this would work. So does this mean we're screwed? Is there any way to fix it?
  • Fri, Apr 18 2008 7:02 PM In reply to
     You might be able to slow down the video by 25% but I don't know how that's going to look. But other than that I don't think there's anything.
  • Fri, Apr 18 2008 7:12 PM In reply to
    • maccorm
    • Posts 13
    • Points 165
     I did try slowing it down already and it looks terrible. Doesn't even come close to looking like the other cameras. This is really bad news...
  • Fri, Apr 18 2008 7:22 PM In reply to
     If you tried 25%, try 20%, because 20% of 30 is 6 frames and that might pull up the 24 to 30.... whereas I'm thinking 25% pulls the 24 upto about 31-32fps; Although that's not all that much of a difference.
  • Fri, Apr 18 2008 11:45 PM In reply to
    • Wm.Busby
    • LA, Cali
    • Posts 234
    • Points 2,790
    In the future, you might want to post in the proper forum. This is the Xpress DV forum.
    Dell Precision 330, 2.6ghz, 1gig ram, 80 gig sys drive, 1TB media, SB Audigy, ADS Pyro, DSR-11, MAudio BX5's, Power Reach Duo KVM, dual Sammies, Win2K... [view my complete system specs]
    Forum etiquette rule #1: FILL OUT SYSTEM SPECS IN PROFILE! :)
