Will 4 pin DV i/o on Adrenaline box take 1394 connection for
DVCPro HD deck?
I've got a 1080i project and see "no inputs available".
If I switch format to SD30i, I get the option to control capture via 1394.
Does Adrenaline "DV" i/o not work for DVCPro HD capture?
Um..if memory serves, you have to bypass the DNA to capture DVCPRO HD.
correct. can't capture any HD material through the dv port on the Adrenaline. Need to connect that firewire direct to the computer and switch the Media Composer to 1394 mode
I tried that with same "no available input" result.
Works with my laptop. Does MCAdrenaline look only at adrenaline
Where if it runs software only on laptop it can see 1394?
thanks will try that
Sorry, dumb question, but where in settings do I switch media composer to 1394 mode?
on the top of the timeline there is a button that says DNA if you click that it will change to 1394 or you can go to the Device menu up top and choose 1394. You can also quit MC and turn off the box and relaunch with it turned off. The button is essentially disabling the Adrenalilne box
ravidedit: You can also quit MC and turn off the box and relaunch with it turned off. The button is essentially disabling the Adrenalilne box
I'd suggest this second solution if you don't have an additional firewire board. Be carful when you hot plug a firewire connector, I have made irreversible damages to our XDCam HD by provoking electric sparkles. This is a solution to avoid this
http://www.kramerelectronics.com/news_full_story.asp?iNews=120
http://community.avid.com/forums/p/46770/263190.aspx#263190
sep
Web site : www.audiacom.com
I have searched the forums and have yet to find an answer for this question and this seems like an approriate thread to follow up in. Does anyone know how to perform this same function (enable 1394 I/O) on a Symphony Nitris? It doesn't seem to be the same method as with MC Adrenaline and I cannot seem to figure it out. TIA!
AFAIK (according to stuff I have read) Symphony Nitris did not support 1394 capture.
This functionality will be added in an upcoming release, though.
out of curiosity, why not just capture DVCPRO HD via HD SDI? FW is irritating with things like this
Eating is a moral act. If you eat meat from factory farms, you partake in a system of cruelty, violence and evil. Always take sides. To be passive empowers the oppressor.
