Latest post Wed, Apr 23 2008 4:02 PM by Guywithcat. 10 replies.
Page 1 of 1 (11 items)
  • Fri, Apr 18 2008 4:10 PM
    • schnitt
    • Joined on Sat, Jan 27 2007
    • Posts 64
    • Points 835
    1394/DV in/out on Adrenaline
    Will 4 pin DV i/o on Adrenaline box take 1394 connection for
    DVCPro HD deck?
    I've got a 1080i project and see "no inputs available".
    If  I switch format to SD30i, I get the option to control capture via 1394.
    Does Adrenaline "DV" i/o not work for DVCPro HD capture?
  • Fri, Apr 18 2008 5:54 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,749
    • Points 174,270
    Re: 1394/DV in/out on Adrenaline
    Um..if memory serves, you have to bypass the DNA to capture DVCPRO HD.
  • Fri, Apr 18 2008 6:27 PM In reply to
    • ravidedit
    • Joined on Mon, Oct 24 2005
    • Los Angeles, CA
    • Posts 647
    • Points 8,095
    correct.  can't capture any HD material through the dv port on the Adrenaline.  Need to connect that firewire direct to the computer and switch the Media Composer to 1394 mode
    Mine: Custom Built AMD 64 3200+/socket 939 2 GB RAM Nvidia 6600gt MC 2.7 Soft Work: dozens of Mac Meridiens, PC and Mac Adrenalines, Unity, Lanshare... [view my complete system specs]
  • Fri, Apr 18 2008 6:28 PM In reply to
    • schnitt
    • Posts 64
    • Points 835
    I tried that with same "no available input" result.
    Works with my laptop.  Does MCAdrenaline look only at adrenaline
    Where if it runs software only on laptop it can see 1394?
  • Fri, Apr 18 2008 6:29 PM In reply to
    • schnitt
    • Posts 64
    • Points 835
    thanks will try that
  • Fri, Apr 18 2008 6:31 PM In reply to
    • schnitt
    • Posts 64
    • Points 835
    Sorry, dumb question, but where in settings do I switch media composer to 1394 mode?
  • Fri, Apr 18 2008 7:48 PM In reply to
    • ravidedit
    • Los Angeles, CA
    • Posts 647
    • Points 8,095
    on the top of the timeline there is a button that says DNA if you click that it will change to 1394 or you can go to the Device menu up top and choose 1394.  You can also quit MC and turn off the box and relaunch with it turned off.  The button is essentially disabling the Adrenalilne box
  • Fri, Apr 18 2008 11:14 PM In reply to
    • sep
    • France
    • Posts 5,593
    • Points 62,520
    ravidedit:
    I'd suggest this second solution if you don't have an additional firewire board. Be carful when you hot plug a firewire connector, I have made irreversible damages to our XDCam HD by provoking electric sparkles. This is a solution to avoid this
    http://www.kramerelectronics.com/news_full_story.asp?iNews=120
    http://community.avid.com/forums/p/46770/263190.aspx#263190
    Adrenaline MCA 2.8 XW8400 3Gb RAM DNxcel Board, 760 Gb striped SCSI media storage, 1.2 TB 4 X striped SAS 15 000rpm storage.----MC Soft 2.8 + Mojo HP XW8000... [view my complete system specs]
    sep
     Web site : www.audiacom.com
  • Tue, Apr 22 2008 4:05 PM In reply to
    • escheck
    • Joined on Wed, Apr 2 2008
    • Posts 4
    • Points 40
    I have searched the forums and have yet to find an answer for this question and this seems like an approriate thread to follow up in.  Does anyone know how to perform this same function (enable 1394 I/O) on a Symphony Nitris?  It doesn't seem to be the same method as with MC Adrenaline and I cannot seem to figure it out.  TIA!
  • Wed, Apr 23 2008 1:57 PM In reply to
    AFAIK (according to stuff I have read) Symphony Nitris did not support 1394 capture.
    This functionality will be added in an upcoming release, though.
    MacPro Symphony Nitris DX (v3.0), MacPro MCA HD (v3.0), Mac Meridien (v12.1.2), Unity LanShare EX (v4.1.6) [view my complete system specs]
  • Wed, Apr 23 2008 4:02 PM In reply to
     out of curiosity, why not just capture DVCPRO HD via HD SDI? FW is irritating with things like this
    HP XW8400 Dual, Dual Core; 4 TB Dulce RAID 5; 3GB Ram; XPRO (latest version); AJHD 1400; HP XW8400 Dual, Dual Core; 7 TB G-TECH RAID 5 (2 encl); 3GB... [view my complete system specs]
    Eating is a moral act. If you eat meat from factory farms, you partake in a system of cruelty, violence and evil. Always take sides. To be passive empowers the oppressor.
