Latest post Mon, Jun 2 2008 1:55 PM by Mike Paterson. 32 replies.
Page 2 of 3 (33 items) < Previous 1 2 3 Next >
  • Fri, Apr 18 2008 1:46 AM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,012
    • Points 71,725
    Re: Let's Build a FAQ!
    carlgmi:
    re-learning where features are as some have moved.  Batch capture for instance - its still there (of course) but not in the bin drop down but in the clip drop down?  Not near the top - half way down.  Sounds silly but I would have looked without seeing for 10 minutes before finding it!
    A pet peeve of mine as well, Engineers, why must you always move things just for the sake of moving them?  Just to prove that you can?  Please, give us all a break and if it ain't broke, don't fix it. I know you guys just LOVE to change things!
  • Fri, Apr 18 2008 2:09 AM In reply to
    carlgmi:
    its the same but different" suggestions.
    Have fun finding Mixdowns they are something Special
  • Fri, Apr 18 2008 12:46 PM In reply to
    • applebuckets
    • Pittsburgh, Pennsylvania
    • Posts 198
    • Points 2,525
    sep:
    applebuckets:
    Q: What is the field order output in Avid MC
    A: NTSC is always lower field first
    PAL varies right?
    There happen sometimes weird things, as mentionned in one of my recent posts. I had lately to encode DV 25 using Procoder 3, and had to sxitch to upper fileld first, using a QT ref coming from a pure DV25 sequence. Here I have NO EXPLANATION. Same bahavior with Sorenson 4.3.
    Oddly enough, after I went to DVD I had a field jitter only on clips where a timewarp effect was applied. My settings were lower field first. When I changed the settings to progressive, the jitter went away and everything looked OK. Not sure why.
    I think clear field order  explainations on the FAQ are a good idea.
    Also, PAR and SAR involving 16:9 vs 4:3. I see a lot of questions on this forum pertaining to that, and a lot of confusion from clients as well.
    MCA 3.0 hp xw8200 3GB RAM Nvidia FX1300 MCA 3.0 hp xw8400 3GB RAM Nvidia FX1400 [view my complete system specs]
  • Fri, Apr 18 2008 4:07 PM In reply to
    • Gerrit
    • Posts 56
    • Points 630
     Editing workflows, especially HD, 24p stuff etc. Something similar to what I think is covered in the 340 course.
  • Sat, Apr 19 2008 8:52 PM In reply to
    • hartfilms
    • Joined on Wed, Nov 16 2005
    • Los Angeles
    • Posts 57
    • Points 645
     I just downloaded a .pdf Working with HDV from the Knowledge Base. It is very detailed.
    Media Composer 2.8.1 w/ Mojo SD, Win XP Pro w/ SP2 System built and upgraded by Avid reseller: ASUS P5W DH Deluxe Motherboard; Intel Core 2 Duo Processor... [view my complete system specs]
  • Mon, Apr 21 2008 12:09 AM In reply to
    • highfly900
    • Portland, OR
    • Posts 63
    • Points 835
    Mike Paterson:
    Why not start a wiki?
    I agree, I think a wiki would be much easier to maintain, quicker to find what you are looking for and subjects can be organized appropiately and structured better than just a long list in a thread.  Maybe just a sticky that points to a Wiki?  I think if done right a wiki good be a huge benefit for the community.  The DS already has one, yet there are more people that use media composer(and more who are going to soon with the upgrade and EOL for Xpress)
    and after looking at the DS wiki it is very basic, i think a media composer wiki could work really well
    thoughts?  comments?
    3.0 Ghz Quad Mac Pro OS X 10.4.11 2GB RAM ATI 1900 MC 2.8 [view my complete system specs]
    -danimal the animal
  • Mon, Apr 21 2008 1:23 PM In reply to
    A wiki is a good idea, but that involves changing the web site, which of course, I can't do.  But I will pass that suggestion along to the web guys.
    In the meantime, I continue to take suggestions for the FAQ, which we'll be posting to the top of the forum.  I'd also like to focus on PC-related things, since there are other forums for other platforms and there are a number of PC-only related issues.
    MacPro Symphony Nitris DX (v3.0), MacPro MCA HD (v3.0), Mac Meridien (v12.1.2), Unity LanShare EX (v4.1.6) [view my complete system specs]
  • Mon, Apr 21 2008 11:42 PM In reply to
    • highfly900
    • Portland, OR
    • Posts 63
    • Points 835
    well i wasnt necessarily referring to changing this website, for example the DS wiki is used through wikispaces.com, and i think going a route like that would work well.  i dont see a wiki working well under avid's domain.
    so what do people think about FAQ/wiki through something like wikispaces.com?
    -danimal the animal
  • Fri, Apr 25 2008 2:43 PM In reply to
    • Mondo
    • Sydney Australia
    • Posts 183
    • Points 2,100
     I can think of a number of FAQ topics - some of these fit more into workflow guides but i figure an FAQ could handle both.
    Above all one of the most posted questions will be: I am thinking about buying X brand video card/Computer/hard drive - will it work with Avid? A note on using only qualified hardware and a link to qualified systems might forestall a lot of these (but I doubt it as we already have something similar..)
    User Settings and Site settings - how to use them to customise your workflow
    Setting up recurring projects (I use a batch file for mine)
    How to find corrupt media (slice and dice)
    Using mixed field order codecs in the one timeline (video mixdown for export to DVD)
    The practical difference between 10 bit and 8 bit codecs (chroma key, colour gradients etc)
    A complete list of compatible decks which can be added to if a user finds one that is not in the list that does work with another template. This could also include hints on how to make particular decks work with Avid. eg - how do you make a UVW1400 deck work as an NLE feeder for Avid (you need an RS232 - 422 converter etc).
    Why don't I hear any sound from my Avid (usually a sync/patching/hardware question)
    How to manage project media (media tool and MDV Avid)
    I sort of understand the reluctance to host a Wiki on another website - it breaks users away from the forum which is after all the main resource.  But an FAQ here will be limited to the most simple topics in forum format. My suggestion would be a simple FAQ here with a link to a Wiki for other topics and workflow guides.
    Adrenaline HPXW8400 3gig RAM FX1500 Mojo Analogue HPXW8000, 3GIG RAM, 380 storage Quadro FX3000 Unity 4.2.3 with 8 terrabytes of storage [view my complete system specs]
    John
  • Mon, Apr 28 2008 8:23 PM In reply to
    • Scott Carnegie
    • Winnipeg, Manitoba
    • Posts 956
    • Points 11,600
    • Moderator: Avid Symphony Nitris
    I really like the wiki idea.
    Several of us built a FAQ for Xpress DV a few years ago that is still out there and still generating hits to this day, though it is very out of date of course.
    http://xdvfaq.tripod.com/
    :: Laptop - Dell Inspiron 5160 - 3.2GHz - 1GB RAM :: Desktop - Asus P5GD2-Deluxe Mobo - Pentium 4 2.8GHz CPU - 2 x 1GB RAM - 3 x 250GB Maxtor... [view my complete system specs]
    "Don't go by my script, they're always wrong." - producer to me while editing
  • Tue, Apr 29 2008 4:23 AM In reply to
    • Mondo
    • Sydney Australia
    • Posts 183
    • Points 2,100
     It seems Multicam may be another topic that just needs covering..
    John
  • Tue, Apr 29 2008 4:30 AM In reply to
    Larry Rubin:
    carlgmi:
    They didn't really "change it" per se...  The menu locations of XpressPro more closely mimic those of NewsCutter.  I am firmly under the impression that XpressPro was a "stripped down" NewsCutter app and not a Media Composer as some have always suggested, based mainly on the menu locations, default snapping turned ON, clicking TC track did not dump out of a mode, etc.
    MacPro dual 2.66GHz 2GB RAM NVIDIA GeForce 7300 GT Storage: 2TB G-Speed eS with controller card 3x500GB Hitachi SATA-II internals various external... [view my complete system specs]
  • Tue, Apr 29 2008 1:19 PM In reply to
    • sep
    • France
    • Posts 5,593
    • Points 62,520
    Kenton.VanNatten:
    Very intersting clues ! Never thought about Newscutter being the Xpress Pro's "grand brother"
    However, I second Larry here, even Newscutter vs MC; why different menu locations for the dame thing ?
    Adrenaline MCA 2.8 XW8400 3Gb RAM DNxcel Board, 760 Gb striped SCSI media storage, 1.2 TB 4 X striped SAS 15 000rpm storage.----MC Soft 2.8 + Mojo HP XW8000... [view my complete system specs]
    sep
     Web site : www.audiacom.com
  • Wed, Apr 30 2008 12:57 AM In reply to
    • Ra-ey Saleh
    • Sydney, Australia
    • Posts 330
    • Points 3,965
    I like the idea of a 'wiki', a lot - from a link from within this forum.
    Can I make another suggestion?  One of the thing I liked best about the DS wiki was it's Top 10 Wish List.  They got everyone to write in their wish list, "someone" collated it all and then made a top ten.  Obviously, most of these ideas have already been asked for in the Feature Requests section, but it was interesting to read what the majority of people wanted.
    The obvious examples would be, Background Rendering; Background Import/Export; Alpha Export support etc...
    HP 8600 Symphony Nitris DX v3 Sapphire v2.07 Boris Continuum Complete v5.8 AvidFX (Boris Red) Heroglyth v2.6 Vitascene v1 Adrenaline (XP 8400)... [view my complete system specs]
    Ra-ey Q: "How many Editors does it take to change a lightbulb?" A: "Why do you want to change it?"
  • Sat, May 3 2008 1:19 AM In reply to
    • highfly900
    • Portland, OR
    • Posts 63
    • Points 835
    well i guess now it just needs to get started, Id say pretty much that means someone stepping up and getting it rolling.
    i wouldnt mind doing that leg work, i think this could be fun!  anyway any recommendations from anyone as to a wiki service?  dswiki uses wikispaces.com.  can anyone recommend any others?  ill do a little research myself but just wondering if anyone had any suggestions.
    also, a domain name, i could register one for easy remembering, what about www.amcwiki.org? (www.mcwiki.org is already taken, i checked)  anyony have any other suggestions for a domain name?
    also is there anything i need to know, ie legal stuff, just wondering if avid would disaprove of the wiki or domain name idea.
    -danimal the animal
