Latest post Wed, May 7 2008 3:15 AM by Ra-ey Saleh. 7 replies.
  • Tue, Apr 15 2008 7:15 PM
    • mrmikster
    • Los Angeleez
    • Posts 229
    • Points 2,510
    • Moderator: Avid DS
    Color grading requests
    Ability to play past clip boundaries
    There may already be a way to do this but, when playing back a graded clip, I want to see the next few clips playback without having to leave color correction mode.
    Power Windows
    I use Power Windows about 90% of the time when grading. Much more critical for me than secondaries. How about Power Windows with built in secondaries?
    More info in Grading Window
    Could we get an info window similar to Photoshop. I need to be able to set anchors that give me values as I move parameters around.
    Luma Ranges
    1) Allow me to grab the whole curve and move it. It currently takes way too many clicks to move the curves around.
    2) Allow me to select any of the curves, without having to specify the button for Shadows, Mids or Highlights.
    Less mouse clicks please.
    Michael
    DS Nitris, Symphony Nitris, Composer [view my complete system specs]
    "There are no rules for the brave". Albert Einstein
  • Tue, Apr 22 2008 5:00 AM In reply to
    • Ra-ey Saleh
    • Sydney, Australia
    • Posts 290
    • Points 3,515
    Re: Color grading requests
    mrmikster:
    Power Windows
    Luma Ranges
    Michael
    Hi Michael, I'm slightly confused as to some of what you're asking for here, but...
    You can, it's called the Edit Review button (which you can map to your keyboard) and allows you to watch the shot in situ whilst still in CC Mode
    Power Windows
    Would be GREAT.  You can use various workarounds to get a similar result: Spot Correction; Colour Effect or Colour Correction Effects combined with Animatte.  But like I said - would be great if it was all embedded into the CC.
    Not sure if this is what you mean, but if you click on either of the RGB boxes on the right, keep it held down and move to the image, the RGBs update.
    You can do this now, just click on teh Curve.  Maybe I mis-understand this...
    HP 8600 Symphony Nitris DX v3 Sapphire v2.07 Boris Continuum Complete v5.8 AvidFX (Boris Red) Heroglyth v2.6 Vitascene v1 Adrenaline (XP 8400)... [view my complete system specs]
    Ra-ey Q: "How many Editors does it take to change a lightbulb?" A: "Why do you want to change it?"
  • Mon, Apr 28 2008 8:54 AM In reply to
    • mrmikster
    • Los Angeleez
    • Posts 229
    • Points 2,510
    You can, it's called the Edit Review button (which you can map to your keyboard) and allows you to watch the shot in situ whilst still in CC Mode<< Cool, that's what I figured, there is a way that I was not aware of.
    Not sure if this is what you mean, but if you click on either of the RGB boxes on the right, keep it held down and move to the image, the RGBs update.<< No, I mean an info box similar to Photoshop. You can leave anchors on the image and as you move values, they report back what the numbers are. Currently, you have to try and move the mouse over the same area and note the values. Then make and adjustment, then  move your mouse over the area to get the updated values.
    You can do this now, just click on teh Curve.  Maybe I mis-understand this...<< I'll give it a shot, I wasn't able to move points on the curve until I selected the radio button. Probably just OE. Still need a way to quickly select all points to move the whole curve around.
    Thanks for the info.
    Michael
  • Thu, May 1 2008 10:09 PM In reply to
    • Haze
    • Posts 306
    • Points 4,110
    mrmikster:
    I'll second this request.  It might help to change the name of the request to:
    Real Time RGB info Update  or something that clearly conveys the feature request.
    As you said this feature works well in Photoshop and I think it works in Color FInesse as well.  If the RGB values updated as you tweaked the curves it would be a huge improvement in the work flow.
  • Tue, May 6 2008 8:58 PM In reply to
    • mrmikster
    • Los Angeleez
    • Posts 229
    • Points 2,510
    O.k. I just had the chance to try Ra-eys suggestions.
    This doesn't work the way it could. You have to choose the curve by the radio button. You cannot click on the curve directly to manipulate it if the appropriate radio button is not clicked. It breaks the flow when you have to move off the curves window to choose another option.
    While this does work, it pre-rolls and plays into the clip then to the next. I want it to play through the clip into the next from the frame I'm parked on. I can drag through the clip to the next, but the playback isn't as smooth.
    I know these may seem nitpicky, but when you're spending 10 to 20 hours in a grading session, its less aggravating when the tools work with you.
    Michael
  • Wed, May 7 2008 1:14 AM In reply to
    • Ra-ey Saleh
    • Sydney, Australia
    • Posts 290
    • Points 3,515
    Michael,
    I really must be completely mis-understanding you, sorry, but...
    My work flow is this with Curves: Hit the Curve Tab, click on a Curve, a Point appears, I move the point - I never have to click on a radio button, ever.
    As for the Edit Review limitation, you're spot on, it would be great it CC mode behaved just like a normal timeline.
  • Wed, May 7 2008 1:48 AM In reply to
    • mrmikster
    • Los Angeleez
    • Posts 229
    • Points 2,510
    Sorry, my bad. We're talking two different sets of curves. I'm talking about "Luma Remapping". The curves there are the basis for all that follows in my grading sessions. They are manipulated point by point. Very tedious when you've got to move the whole curve.
    Michael
  • Wed, May 7 2008 3:15 AM In reply to
    • Ra-ey Saleh
    • Sydney, Australia
    • Posts 290
    • Points 3,515
    Got ya, and yeah, completely agreeBig Smile
