Latest post Wed, Apr 16 2008 11:54 AM by sep. 61 replies.
Page 4 of 5 (62 items) < Previous 1 2 3 4 5 Next >
  • Tue, Apr 15 2008 11:24 AM In reply to
    • sep
    • France
    • Posts 5,583
    • Points 62,350
    Re: NAB news from Avid?
    AndrewAction:
    Job ter Burg:
    TC I/O over XLR (just like 'old' Nitris)
    Thank goodness I kept those old cables.
    WTF would you go back to using XLR's for TC when you are already short of backplane real estate? Interesting to see if the new thinking has them change the XLR's pin assignments just because they can.
    There's something I misubderstand here !
    TC is on XLR connectors on Meridien and Adrenaline, or am I wrong ?
    Adrenaline MCA 2.8 XW8400 3Gb RAM DNxcel Board, 760 Gb striped SCSI media storage, 1.2 TB 4 X striped SAS 15 000rpm storage.----MC Soft 2.8 + Mojo HP XW8000... [view my complete system specs]
    sep
     Web site : www.audiacom.com
  • Tue, Apr 15 2008 12:19 PM In reply to
    • filmbin
    • Joined on Sat, Feb 18 2006
    • Posts 44
    • Points 640
    JVC 25P / 720p25 - What I've been waiting for, but seems like I have to buy a new computer, and the nw8440 laptop seems not to be supported either?
    http://pro.jvc.com/pro/pr/2008/nab/avid.html
    Dell Precision 670 Single 3.2 Ghz Xeon 2 gigs RAM Nvidia Quadro FX 1400 2x250 GB SATA HDs 2 PC monitors and 1 client monitor Xpress HD 5.7 Mojo [view my complete system specs]
  • Tue, Apr 15 2008 12:54 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 4,913
    • Points 58,755
    AndrewAction:
    ...if the new thinking has them change the XLR's pin assignments just because they can.
    Oh Lord help us, save us from the engineers!
    Media Composer Adrenaline PC v 2.7.7 * Newscutter Adrenaline PC v 6.7.7 * XDCAM PDW-1500 & PDW1 * PDZ-1 XDCAM Browser * Pixelan SpiceMaster 2.0 plug... [view my complete system specs]
  • Tue, Apr 15 2008 2:13 PM In reply to
    • sasfog
    • Bristol United Kingdom
    • Posts 162
    • Points 1,945
     Thanks sep,
    I had already seen those, I thought you had found some glossy brochure type thing with nice colour pictures and stuff in PDf.
    Thanks again
    Pentium 4 3.4 GHZ ASUS P4P800 2GB DDR SDRAM PC 3200 80GB 7200RPM Hard Drive NVIDIA GEFORCE FX5200 128MB AGP Graphics MC 2.8 with Mojo (not SDI) Sony... [view my complete system specs]
  • Tue, Apr 15 2008 2:55 PM In reply to
    • sep
    • France
    • Posts 5,583
    • Points 62,350
    sep
  • Tue, Apr 15 2008 3:53 PM In reply to
    • sasfog
    • Posts 162
    • Points 1,945
     That's the kind of thing,
    saw it in the earlier thread you started about is adrenaline dead. I guess Avid will bring out some official literature in due course.
    Ii am a bit suprised that particualr post hasn't been edited out in view of the controversy surrounding its posting.
    Thanks again
    Graham
  • Tue, Apr 15 2008 5:46 PM In reply to
    sep:
    No... you are right. (note to self check the aging Adrenaline  before posting next time)
    I was thinking (or not) more about every professional deck here having TC on BNC's for more than two decades (read note to self above and checked the dusty old Sony UMatic HiBand (from the early 80's) in the corner and it has BNC's for TC) If you have a 2 point connector on one end then why use a large 3 pin connector on the other end.
    So I should now modify my comment to "WHY would you CONTINUE to USE XLR's for TC when you are already short of backplane real estate?
  • Tue, Apr 15 2008 6:02 PM In reply to
    • sep
    • France
    • Posts 5,583
    • Points 62,350
    AndrewAction:
    ]No... you are right. (note to self check the aging Adrenaline  before posting next time)
    Yes, the U-Matic Hi Band VTR's (we already have one,  a Sony BVU950, we keep our older shots, and want to be able to play them), had a BNC connector for TC, right.
    sep
  • Tue, Apr 15 2008 6:12 PM In reply to
    • fdooman
    • LOS ANGELES
    • Posts 136
    • Points 1,650
    Amitzinman
    Yes, it is a good setup. You would probably get a bit more out of it if you install Vista 64bit if you can get drivers (and then turn down all of its gizmos).
    Then, I should be ok with the current system. I just have to install the windows Vista 64 bit. What about my CPU at 3.0 GHZ? Should I upgrade the CPU to 3.66?
    Fred
    Dual Xeon 3.0, Supermicro X6DAE-G2 MB, PNY Quadro FX 1500 PCIe video card. 4 GIG ram. Two Seagate 200 GIG set as Raid 0 for video drive, Seagate 160 GIG... [view my complete system specs]
  • Wed, Apr 16 2008 12:00 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 3,162
    • Points 36,290
    sep:
    I've never really understood why analog timecode, an audio signal, should be sent via BNC.  Until Sony introduced the idea for space reasons no-one ever did.  Avid never have, and nor has Lightworks.  No master timecode generators did (not true now though).
    Why criticise Avid for persisting in using a widely accepted audio connector for an analog audio signal?
    MC 3.0 - Gigabyte GA-X38-DQ6 mobo - Intel core 2 Extreme Q6850 3 GHz - nVidia Quadro 1700 - 4 Gbyte mem - Internal 4 Tb SATA II 4-way RAID 5 array - Pyro... [view my complete system specs]
  • Wed, Apr 16 2008 6:54 AM In reply to
    AndrewAction:
    DVW500? XLR.
    BVW75? XLR.
    Or aren't these professional decks?
    Symphony Nitris 3.0 on 2xquad core XW8400/4(??)GB | MC 3.0 on dual core XW8400/3GB | Mojo SDI | Unity Lanshare 4.23 fibre | MC 3.0 on MacBook 2.16/2.5GB... [view my complete system specs]
  • Wed, Apr 16 2008 7:06 AM In reply to
    I understand this is not your first language but you may notice I qualified "every professional deck" with HERE" I dont know anyone would have seen, let alone remember the TC IO, for every professional deck.
    All the professional cameras I have known over 2 and a half decades have also use BNC's for TC IO's
  • Wed, Apr 16 2008 7:50 AM In reply to
    I'm not sure that I appreciate the tone of voice, Andrew. For the record: 'where'? In your office? In your part of the world? Must be my English, I guess.
    To me, DVW and BVW machines were pretty much industry standard over the past two decades you were referring to.
    But can't we agree that it doesn't really matter? Both XLR and BNC TC I/O's have been around for decades. I'm sure it has to do with the use in both video and audio environments, just like AES 75 and AES 110.
    Avid isn't really doing anything wrong or different. A storm in a glass of water, as we say 'here'.
  • Wed, Apr 16 2008 8:26 AM In reply to
    Does anybody know if there are any timecode in and outs on the Mojo DX at all?
    Formerly known as HDRebel88
  • Wed, Apr 16 2008 9:28 AM In reply to
