Latest post Mon, Apr 14 2008 6:44 PM by schnitt. 17 replies.
Page 2 of 2 (18 items) < Previous 1 2
  • Mon, Apr 14 2008 4:47 PM In reply to
    • schnitt
    • Joined on Sat, Jan 27 2007
    • Posts 64
    • Points 835
    Re: Workflow Check request
    Thanks.  Ok..last question (I think)
    If I work in a 23.98 timeline (SD or HD).
    I will output image seq. for color correct.
    Then to 1080i master.
    How about mix prep?   I will need to output quicktimes and omfs for the audio engineer.
    This is new territory for me.  What steps should I take for mix elements from a 23.98 timeline
    that will eventually layback to a 1080i master?
  • Mon, Apr 14 2008 6:34 PM In reply to
    You can make 23.98 or 60i Quicktimes for them. No speed changes anywhere. With 23.98 QT's they will have the most accurate reference.
    As for HD decks: keep in mind that those can be rented.
    I'm also not too fond of purchasing an HD-SR, that I will likely use 4 or 5 days per year.
    Symphony Nitris 3.0 on 2xquad core XW8400/4(??)GB | MC 3.0 on dual core XW8400/3GB | Mojo SDI | Unity Lanshare 4.23 fibre | MC 3.0 on MacBook 2.16/2.5GB... [view my complete system specs]
  • Mon, Apr 14 2008 6:44 PM In reply to
    • schnitt
    • Posts 64
    • Points 835
    Thank you again.
    So I'll just give engineer a 23.98 Quicktime
    He'll mix at 23.98
    Output an aif full mix
    and no problem with layback to 1080i tape?
    Sounds good.
    And yes, I think I can convince the handful of clients for which I would output a master
    that for HD broadcast and/or Web delivery we will be well served with HDcam.
